Author Topic: 1425 Pentronics monitor will not adjust  (Read 2184 times)
fairway2000
  • Last login:April 21, 2012, 06:53:54 pm
  • Loooking for games in Detroit
« on: May 13, 2006, 11:38:25 pm »
I have a model 1425 Pentronics monitor.I can not get the picture to stop rolling or bending and jumping.I just installed 2 . The first took about 2 min. to adjust.
One thing it does is makes a pop noise and ark's around the ground strap that raps around the out side of the monitor. What am I missing? I did change the remote adjusting board.
Now it will at times slowly go dark. Like it is loosing power.
Thanks for any help.
« Last Edit: May 15, 2006, 10:12:38 am by fairway2000 »
grantspain
Re: 1425 Pentronics monitor will not adjust
« Reply #1 on: May 14, 2006, 04:06:31 pm »
if you have arcing to the earth strap then its likely to be a damp/dirt issue on your ht lead-as for your picture issue,do you have a curve at the top of the picture?
fairway2000
« Reply #2 on: May 14, 2006, 04:49:27 pm »
It is rolling left right up and down. I can see the picture.
grantspain
« Reply #3 on: May 14, 2006, 05:28:13 pm »
whats the history on this monitor,by what you say now its a frequency or sinc problem,what are you trying to display mame or standard arcade
fairway2000
« Reply #4 on: May 14, 2006, 07:04:44 pm »
It is a new kit that I put in my old frame. The game is a California speed. I have 2. The other monitor is the same. And works in the game I have the problem with. So we know it is not the game.Thanks for the help.
I am running it at med. rez (25). I have tried standard (15) and it is the same.
« Last Edit: May 15, 2006, 11:07:44 am by fairway2000 »
grantspain
« Reply #5 on: May 15, 2006, 02:39:07 pm »
sounds like a fault on the flyback,if its new get it replaced by the seller
fairway2000
« Reply #6 on: May 16, 2006, 11:52:43 am »
Would you think it could be the picture tube? Need to know witch one to replace first.
grantspain
« Reply #7 on: May 21, 2006, 06:57:26 pm »
tube faults are extremely rare,i very much doubt this is a tube fault-just exchange the chassis
