Author Topic: Looking for the lighting in the old style jukes. LED's would be an option......  (Read 1319 times)
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
I am thinking about using those lights used in the bubbles of old jukeboxes.  I know it's not rocket science, but where can you buy those things?  You know, the lights that rotate and change colors behind frosted plastic.  They were typically on the sides of all cool looking jukeboxes.  I found a company on ebay that sells the outer shell, but now I need to find the lighting that goes behind it.
Ken Layton
  • Guru
  • Technician
Those animated color cylinders were very popular on Wurlitzer & Seeburg jukes in the late 1940's and early 1950's. They had an F15T8 fluorescent light in them as the light source. You can buy the entire assemblies as reproduction parts from www.victoryglass.com
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
You can make your own..... Much cheaper than buying them.  Find a Stage Lighting supplier on the internet and buy colour gels (thin coloured plastic, heat resistant, flexible, sheeting.) This stuff is quite cheap and comes in virtually any colour you can think of.
Then you need a cheap, low speed motor and gearbox to drive it. Lots of places on the internet have these.
Make a frame to hold the lighting gel, and that's all there is to it. You can make it up as a colour wheel or as a rotating tube.
The DIY method is more fun than buying the stuff and probably with better results.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
melarky
  • Last login:July 12, 2020, 12:49:22 pm
  • If I could be any animal, I would be a llama
do you mind sharing the ebay link where you found the outer shell?
