Author Topic: A Venture into Cocktail Cabinets  (Read 5577 times)
russtophiles
  • Last login:May 23, 2003, 12:17:27 pm
« on: March 02, 2003, 01:23:05 pm »
Hi, I'm starting to conceptualize a cocktail MAME cabinet that I'll be making for my 3D design art class and more importantly, myself, and I just wanted to see what you folks think.
Since this will be my first foray into cabinet construction, I've decided to keep things fairly simple. Essentially, I'm going to make the cabinet so that a computer's tower can just be stuck right into the cabinet without having to gut the machine and mount all the parts inside the cabinet, seeing how that would consume more time, and I have time constraints, plus I'd rather maintain the computer I'm using for the cab as useable as a normal computer if I so decide to. Same thing with the monitor, except it wouldn't be as easily swappable I would imagine. I don't intend on opening any casing on the tower or the monitor, unless it's just to take off the tower's casing to give it better ventilation.
The cab itself I intend on making it 2 players, with the controls at the longest ends. The controls I've already ordered from those X-gaming auctions, as mentioned in another thread here, since the price is right and although I've heard ups and downs from you all, they should suit my purposes just fine. I intend on using an I-pac to connect the controls to. I would LIKE to try to make the monitor rotatable to spin around so that the other player could see right for games that may require it, but in a more manual way without motors and chains and all that, something simple like a turntable that could be cranked from the outside of the cabinet perhaps.
The computer I'd be using is a 450 Mhz Pentium 3 Compaq with a GEforce 2 64MB, and 384 MBS of RAM, and the monitor is a 17" Compaq model. The computer handles pretty much any game I could possibly want to play on a cocktail cab with ease. Simple stereo speakers I have laying around should do the sound just fine.
With this setup I think I'll be able to minimize the amount of wiring I have to do ( I've never wired before, although I have mild experience with a soldering iron ). I've diligently read through many articles and tutorials on this smashing site, so I've got a pretty good idea of what lies ahead of me.
In close, I have a few questions for you all. First, would it be okay to just stick a tower inside the cabinet in terms of cooling? Would it be a good idea to remove the casing of the tower? Could I just cut an air vent or should I get a fan to vent the cab? As for the speakers, where does one put them on a cocktail cab? Do they even have an opening or are they completely sealed within the cab?
That's all I can think of for now, any feedback would be mucho appreciated.
Smack
  • Last login:May 07, 2013, 11:40:41 pm
  • Who changed my avatar?
Re:A Venture into Cocktail Cabinets
« Reply #1 on: March 11, 2003, 12:36:36 am »
The space is pretty tight inside of a cocktail cab, plus you need some good venting + fans. The monitor will generate quite a bit of heat in the enclosed area. I had a lot of problems with mine initially.
The speakers mount flush to the inside wall of the cabinet against either some mesh or behind a speaker grille.
I know that I had to take my 'puter outta the case to make everything fit in my cab. (I retrofitted an old one.)
If you're designing the whole cab from scratch, you could probably make a space for the computer case (if you've got a mirco-atx case or something, but it will be tight)
Here's a pic of my motherboard mounted inside mine:
Good luck with your project and POST SOME PICS BABY... ;D
My 2 cents.
Smack
Never Let Donkey Kong Use Your Toilet.
(We're talkin' big processed brown bananas...)
Somebody out there stole my sig! LOL
anthony691
  • Last login:January 29, 2016, 03:10:23 pm
    • Lightgun.tk
« Reply #2 on: March 11, 2003, 04:21:55 pm »
I started a cocktail cab this weekend, with 3 men and over 100 man hours it is almost done! We have all of the CPs mounted ect. I have some advice for you! make one 2 player cp on a long side for vertical games and 1 one player on each short side for cocktail games. If you need to see a pic of this I should probably take a pic of my cab so far. We have the whole thing together minus the top piece we even cut plexi for the cps already.
Visit my MAME lightgun site:
http://www.lightgun.tk
BobA
  • What Me Worry?
« Reply #3 on: March 11, 2003, 04:30:23 pm »
Sounds good.  Looking forward to pictures.  Specially how to get that 2 player panel mounted so it looks like part of the cab.   Love the way Hanaho inset their 2 player side control but looking for simpler alternatives.
BobA
anthony691
    • Lightgun.tk
« Reply #4 on: March 12, 2003, 08:19:00 pm »
Here is an old pic of my WIP cab. If anyone is interested in more pics, I have a million.
russtophiles
« Reply #5 on: May 06, 2003, 05:03:34 pm »
Well it took a while to get everything in order, but here's the more or less finished control panel, lousy printer gave me the most trouble with the colors, it kept making my blues turn out as purples.....so after a little compromising,  and monitor tuning my lame looking art came out. Sorry if it stretches the tables out a bit.
The main cabinet construction just began yesterday, and I've gotten 3 sides and the bottom glued and nailed together. I've only got another 2 weeks to finish this bad boy for my class, so I'm going to have to go into OVERDRIVE to get everything going good before then.
« Last Edit: May 06, 2003, 05:06:39 pm by russtophiles »
anthony691
    • Lightgun.tk
« Reply #6 on: May 06, 2003, 07:58:10 pm »
Wow! I finnished mine that 1 weekend!
SirPeale
  • Green Mountain Man
« Reply #7 on: May 07, 2003, 12:59:07 pm »
Yes, please!
anthony691
    • Lightgun.tk
« Reply #8 on: May 07, 2003, 06:29:45 pm »
Yes, please!
I'll get those posted ASAP. It is done, but I did not get any pictures of it finished before it went away to college (It is double majoring in Mathematics and Bio-Chem at the University of Chicago it thinks it wants to be an academic; Okay, so maybe that is my brother, but it is his cab)
I will ask him for some pics, but his camera sucks. The CPs are nothing speacial like the above though, they are just transparent Plexi; We are still working on some cool lighting.
russtophiles
« Reply #9 on: May 23, 2003, 12:23:37 pm »
Well, this week I finally finished the cab. I may end up adding a few little things here and there if I feel like it later on, but right now I'm happy with what I have. Pardon the blurriness, the light indoors sucks.
I added two buttons on the side of the cab on the one player side for video pinball games, and added 4 buttons on the CP side of the one player for system functions (escape and enter) and for coin entering for both players. I'm happy with the result overall, although I wish I'd sanded some of the rougher ends of the wood a bit better, but it's not that big of a deal.
armad1ll0
  • Last login:March 28, 2012, 12:24:57 pm
  • The player and the builder!
    • Modeverything
« Reply #10 on: May 24, 2003, 04:39:15 pm »
Hmmmm I'm just more into the more classic looking cocktail machines. I like the replicas that people have done. I may get a kit sometime and try to lower the thing a bit. I wonder how hard would it be to make a 3rd side panel (horizontal games) be able to be bolted on easy.
