Author Topic: Softer springs for E-stick!  (Read 2104 times)
1UP
  • Token Junkie
    • 1UPArcade
« on: March 02, 2003, 01:42:36 am »
I was playing Pac-Man on crack mode (speedup cheat) last night, and my wrist got all cramped after a couple screens.  So I took the E-stick apart (my dedicated 4-way since it does diagonal games too) and pulled out the spring for the shaft and found it to be too stiff.  I started to wonder if it could be replaced with something softer...
Tonight I went to Home Depot and found a spring of the same approximate size, but made of a thinner gauge wire.  Popped it in the E-stick, and now it feels just like a Happ super (but with a shorter throw.)
The spring was a "Handyman Springs" brand (Prime-Line Slide-Co), part# SP-9706.  The specs are 1/2" x 1-1/2" x .041
« Last Edit: May 18, 2003, 03:28:27 pm by 1UP »
My other job...
