Author Topic: Armed Switches...  (Read 2698 times)
M6A4TS
  • Last login:August 25, 2005, 02:28:52 pm
  • Leader of the Ewoks
Armed Switches...
« on: March 01, 2003, 10:07:10 pm »
Does anyone know where I can find, or even what the name of those switches that have the plastic coverings over them that you have to flip up and then there is a button or switch on the inside, like those found on fighter planes to launch missles in the movies.  ANY leads or help would be appreciated!
Thanks in Advance,
M
1UP
  • Token Junkie
    • 1UPArcade
Re:Armed Switches...
« Reply #1 on: March 01, 2003, 10:11:42 pm »
You can probably find something like this if you look for safety switches for industrial equipment.
My other job...
M6A4TS
« Reply #2 on: March 02, 2003, 11:54:25 am »
Thanks 1up! still no luck finding them though, just think how cool it would be to power on your arcade machine with a switch like that!
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #3 on: March 02, 2003, 12:06:40 pm »
Well, that might be cool... but it might be neater, for those of you/us who have function buttons on your CP it might be a neat way of protecting a Shazzaaam! or "esc" or "reset" key from being accidently depressed during gameplay.
Sorry, no help on locating 'em though... have you check the regular electronic parts sites? Mouser, jans etc?
*Shrug*
rampy
Kilgore
  • Last login:September 27, 2021, 10:53:34 am
  • Mmmmm, Video Games...
« Reply #4 on: March 02, 2003, 12:19:46 pm »
Recently at an AutoZone I saw these switches available in the selection of accessorie switches.  I wasn't able to find them online though.
killr0y
  • Last login:November 03, 2003, 03:41:29 am
  • The Dude abides
« Reply #5 on: March 02, 2003, 12:28:36 pm »
something like this?
HotDogg
  • Last login:April 14, 2012, 03:05:41 am
« Reply #6 on: March 02, 2003, 12:47:48 pm »
Check out this link they have covers that go over a toggle switch like in killr0y's picture.
http://www.action-electronics.com/switches.htm
$13.75 seems pretty steep but then again you can't put a price on safety can you?
FYI I've never ordered anything from this vendor so perform your own due dilligence.
« Last Edit: March 02, 2003, 12:48:39 pm by HotDogg »
-- Signatures, we don't need no stink'n signatures! --
BobA
  • What Me Worry?
« Reply #7 on: March 02, 2003, 12:49:45 pm »
You can often get these swiches for auto supply places that sell nitrous oxide rigs for souping up your car.  Don't want to inject nitrous by accident.
BobA
HotDogg
« Reply #8 on: March 02, 2003, 12:59:29 pm »
Perhaps slightly OT but if you are going to pursue this make sure the switch functions the way you want it to.  That is if you want it to function like a button push in a game it should be a momentary switch.  Cool idea, let us know if you move forward.
Xphile
  • Last login:July 03, 2010, 12:54:48 am
  • I'll never go back to the NHL!
« Reply #9 on: March 02, 2003, 01:05:39 pm »
that *would* be great for the shazzam/shift button!
I just can't get over the cool ideas that get floated on this board..:-)
Pull a year and a half strike- it's over 4eva..
besides, WHL rocks!
BobA
  • What Me Worry?
« Reply #10 on: March 02, 2003, 01:08:45 pm »
If you can get the cover alone you should be able to substitute a toggle switch with any action you need.  In the pic I posted it looked like the cover was separate so any standard size toggle would work with it.
BobA
M6A4TS
« Reply #11 on: March 02, 2003, 07:36:54 pm »
Wow the resources this board provides are simply amazing!
Thanks guys I just need to find a way to use something momentary with one of those covers... But this has me thinking, wouldnt this make a kick @$$ enable/disable switch for a mod chip on an xbox?
-M
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #12 on: March 03, 2003, 12:13:39 am »
Check out this catalog in Acrobat Reader format:
http://www.clicfix.com/images/Clicfix_72res.pdf
They have a switch/button that requires inserting and turning a key.  They always have to use those things to fire nuclear missiles or open important vaults in the movies.  Better yet, put one on each side of your cab and have two people wear the keys around their necks at all times so it can't be turned on without both of your consent.   ;)
Best Kid iPad Apps
X-0
  • Last login:October 15, 2003, 10:48:38 am
« Reply #13 on: March 03, 2003, 01:24:40 pm »
Try Mouser, Digi-Key, MCM electronics, or maybe (maybe) Parts Express
http://www.mouser.com/
http://www.digikey.com/
http://www.mcmelectronics.com/
The above 3 are pro electronics supply houses, very fast and reliable.  You can also get their (better) paper catalogs quite easily, though once you start you may never get them to stop :)
http://www.partsexpress.com
PE is more geared to audio/car audio DIY types, but may have those switches (we normally called them safety switches).  You can also try to find an electronics supply house locally, something more in-depth than a Radio Shack (though RS may have them, just about every switch I ever got from them has been cheap and wore out/broke very quickly).  PE is also very very quick and very reliable.
BTW: hello, I'm new here.  My apologies if I'm posting info that's common knowledge.  I'm still immersed in the FAQs, and trying to read through all the forums at the same time.
« Last Edit: March 03, 2003, 01:26:57 pm by X-0 »
rampy
  • *shrug*
« Reply #14 on: March 03, 2003, 01:58:19 pm »
Hey X-0,  welcome... nah. you are doing fine... that's probably the most informative/useful frist post in a while =P
Rampy
X-0
« Reply #15 on: March 03, 2003, 05:28:47 pm »
 ;D ;D
It's worth noting that those electronics supply places I posted will also have a wide assortment of multipin connectors for use in the modular CP's I have been reading up on:  take your pick of locking, threaded, or simpler types of connectors, anywhere from 3-9 pins up to over 40.  AMP and Mil-Spec are reliable manufacturers of such connectors, and Mouser and Digi-Key will sell any type of Molex plug.
