Author Topic: Feature request re: Quit  (Read 6277 times)
BobA
  • What Me Worry?
« on: May 04, 2006, 10:35:51 am »
Is it possible to add an option that allows the quit to allow either quit to windows or shut down windows?  This alows the PC to be shutdown properly from just a keypad.
Thanks for your efforts.
BobA
SalmonKing
  • Moderator
  • Last login:August 16, 2007, 10:45:44 am
  • SK Jukebox
Re: Feature request re: Quit
« Reply #1 on: May 04, 2006, 10:49:06 pm »
Yep, I put in what I call the 'Admin Panel' a while back that allows you to do this.  Just make sure you don't have the 'Do Not Use Admin Panel' option ticked first!
Then, you just need to enter '99997' as the song number.  This is just an example, based on somewhere between 100 & 999 albums.  If you have 10 to 99 albums, put in '9997' as the song number.  If you have 1000 to 9999, '999997' is what you want to use.  Basically as many 9's as the length of the album numbers, followed by '97'.
BobA
  • What Me Worry?
« Reply #2 on: May 04, 2006, 11:35:32 pm »
Thanks, sounds just like what I need.  Great work.
BobA
