Author Topic: mamewah and catver.ini  (Read 4628 times)
tkuper05
  • Last login:February 20, 2022, 07:57:24 pm
  • I find your lack of buttons disturbing.
« on: May 03, 2006, 11:57:48 pm »
I can't get my catver.ini file to work with mamewah.  If my catver file is for mame version .99 will it work with .105?
Re: mamewah and catver.ini
« Reply #1 on: May 04, 2006, 05:02:09 am »
Yes but obviously newly added games will not have any category info.  Point to catver.ini in your (mamewah) mame.ini file, and ensure you generate the list *after* this.
tkuper05
« Reply #2 on: May 04, 2006, 05:54:21 pm »
I pointed the (mamewah) mame.ini to the catver.ini file.  Then I "re-generated" the main list.  I did research this but couldn't find anything to help me.  My catver.ini is in my mame folder.
« Reply #3 on: May 08, 2006, 05:13:22 am »
Sounds like you did everything right....maybe post your (mamewah) mame.ini file...
tkuper05
« Reply #4 on: May 08, 2006, 07:43:09 pm »
### 01mame.ini (mamewah v1.61) ###
emulator_title                            Arcade
### List Generation Settings ###
rom_path                                  G:\Emus\zinc\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file                           C:\mame\catver.ini
list_generation_method                    rom_folder_vs_listxml
### Execution Settings ###
emulator_executable                       c:\mame\mame.exe
commandline_format                        [name]{nodosbox}{safelaunch}
alt_commandline_format_1                  [name]{nodosbox}{safelaunch}
alt_commandline_format_2                  [name]{nodosbox}{safelaunch}
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path                      C:\MAME_0.102\MAME_Extras2\titles
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               1
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]{nodosbox}{nosafelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable                          C:\Program Files\CPViewer\cpvw.exe
app_1_commandline_format                  -r=[name] -c=[cloneof]
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              2
« Reply #5 on: May 09, 2006, 04:47:22 am »
Could it be that this should be pointing to your MAME roms folder??
tkuper05
« Reply #6 on: May 09, 2006, 10:30:06 am »
No. I know it's weird but I was having problems with zinc and it didn't like having it's rom folder outside of it's directory.  Mame accesses those roms fine.  I found a different version of catver.ini and I'm going to try it when I have a chance.  Thanks for looking at my mame.ini Minwah
« Reply #7 on: May 09, 2006, 11:44:18 am »
No problem, it looks fine apart from the unusual rom path.
ppilot
  • Last login:January 06, 2020, 01:33:27 pm
« Reply #8 on: May 09, 2006, 01:30:52 pm »
I had this problem too.  In (version 1.61) the 'files' subdirectory, for some reason all of the files that ended in .ftr were empty.  I deleted the one that ended in -0.ftr (filtered list) and did a generate list, then I got my catver information again.  If I remember correctly all of the .ftr files were blank, so I may have deleted them all.
« Last Edit: May 09, 2006, 01:38:10 pm by ppilot »
tkuper05
« Reply #9 on: May 09, 2006, 03:42:02 pm »
Well I now have the option to sort by category but now mamewah lists the rom names and not the game names   :(.  I changed the list generation method to rom_folder and then changed it back to rom_folder_vs_listxml but mamewah still just lists the rom name and not the "game name".  I have re-generated the main list but nothing has helped.
ppilot
« Reply #10 on: May 09, 2006, 05:19:29 pm »
I'd suggest you delete everything in the 'files' folder and try again.  Make sure you have xml2info.exe in your mame folder.
tkuper05
« Reply #11 on: May 09, 2006, 06:48:57 pm »
I ended up downloading a .dat file for mame 105 and then changing the list generation method to rom_folder_vs_dat_file.  That seems to have solved it.  I think my original problem was my version of catver.ini.  The one that worked for me was from www.catver.com.
