Author Topic: wire up multiple systems to a single arcade cabinet?  (Read 1546 times)
dougman
  • Last login:February 10, 2007, 01:15:46 pm
« on: May 02, 2006, 03:05:52 pm »
how to wire up multiple systems to a single arcade cabinet?
I am planning to put in an xbox and a PC into my cabinet.
The controllers i hooked up are Xbox+PS2+gamecube all in one controllers, and the lightguns are LCD topgun all in one.
I can hook up all the systems individually, if i unhook and switch the video and controllers.  Is there a good way to put it all into one switch?
tkuper05
  • Last login:February 20, 2022, 07:57:24 pm
  • I find your lack of buttons disturbing.
Gatsu
Re: wire up multiple systems to a single arcade cabinet?
« Reply #2 on: May 02, 2006, 07:16:41 pm »
Glad someone else posted this. I was wondering the same thing. Its all so simple! I've got a couple of those cheapo-walmart switchers laying around. I can just slide it into the keyboard drawer!
now for a question to dougman, what did you use to wire that controller? A splitter and converters? or a custom wire job? Or was it a universal controller?
dougman
« Reply #3 on: May 02, 2006, 09:27:34 pm »
Hmmm.. looks like i have to get a BUNCH of switchers. since the controllers have 4 pins each (USB/Xbox), lightguns are another bunch of pins and the video is 5 pins each.  :O
I hacked apart my soul calibur 2 universal joysticks.  They are always on sale for like $20 or less.
Helmgar
  • Last login:August 31, 2015, 01:52:41 pm
« Reply #4 on: May 03, 2006, 11:24:16 am »
If you don't mind hacking apart the cables you could use something like thisDB25-4 Manual 4-Way Data Switch Box
« Reply #5 on: May 04, 2006, 05:18:54 am »
I made custom leads to combine video/audio/controls/power switch into one cable per system.  I used hacked printer cables and a printer switchbox...so everything is switched at once :)
Sorry it's not very detailed but there is a little bit about it here: http://forum.arcadecontrols.com/index.php?topic=18812.120
