Author Topic: Router Diameter for the following???  (Read 1425 times)
lettuce
  • Make It So!
« on: April 30, 2006, 10:49:37 am »
If i want to mount the following sticks and spinner, under my 1/2 " MDF Contol Panel, what diameter do the holes need to be routed at, so the shafts fit and enough for normal joystick movement?
Happ Comeptetion stick
Happ 49 way
Groovygamegear turbo spinner??
Moby Ick
  • Last login:February 12, 2007, 12:41:24 pm
Re: Router Diameter for the following???
« Reply #1 on: April 30, 2006, 03:44:42 pm »
I wouldn't route. Use a Forstner bit (my favorite) or a spade bit.
I find the 49 way works great with 1 1/4 inch, 1 1/8 will knock of the far corners if the joystick isn't centered perfectly. I assume the other Happ can just use a 1 1/8. The spinner need less then 1/2 inch.
mike
lettuce
  • Make It So!
« Reply #2 on: April 30, 2006, 08:17:26 pm »
Whats a Forstner bit, by the way. Is 1 1/4 the same used for push buttons??
Moby Ick
« Reply #3 on: April 30, 2006, 11:25:03 pm »
What is a forstner bit:   http://www.wisegeek.com/what-is-a-forstner-bit.htm
Pushbuttons use a 1 1/8 hole
Mike
miles2912
« Reply #4 on: May 01, 2006, 12:28:02 am »
This is the set I bought.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=39811
Usually a single bit will run you 25.
Don
Moby Ick
« Reply #5 on: May 01, 2006, 01:00:58 pm »
I've had great luck with Rockler. http://www.rockler.com/product.cfm?page=6401 . Their router table is awesome, really solid, great attention to detail.  They have an add on for their Forstner bits (pictured below) that will help you get nice straight holes as well without a drill press. I think some of the more expensive bits are Carbon. Not sure how quick the steel ones dull cutting through MDF and Laminate.
Don't forget a 3/32 slot cut bit if you plan to apply T-molding (you won't find that one at Home Depot).
miles2912
« Reply #6 on: May 01, 2006, 01:46:19 pm »
I would use a 1/16 bit.  The 3/32 will be too big unless you want to glue the t-molding in and not just tack it in.
Don
lettuce
  • Make It So!
« Reply #7 on: May 01, 2006, 02:17:54 pm »
Ok cheers guys, what about if i wanted to add plexiglass to my 1/2 " MDF CP, what size would i need for that so the T-Molding would be flush with the top of the plexi?
