Author Topic: Uneven joystick recess  (Read 1146 times)
tkuper05
  • Last login:February 20, 2022, 07:57:24 pm
  • I find your lack of buttons disturbing.
« on: April 28, 2006, 02:30:48 am »
When I made my first CP I used a chisel to recess my joysticks.  I think they are uneven a little bit.  Would this cause any performance issues for the Happ Supers I have installed?  Would they perform any different than one attached to an even surface?
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
Re: Uneven joystick recess
« Reply #1 on: April 28, 2006, 07:18:51 am »
My biggest concern in that situation would be whether they were centered around the joystick to allow free movement of the joystick on all directions.  As long as that is verified, while not my prefered way, it should work.
GoPodular.com
  • Last login:April 23, 2008, 10:09:55 pm
    • GOPODULAR!
« Reply #2 on: April 28, 2006, 09:14:02 am »
Uneven (crooked)?
That might be noticable.
Uneven (wavy bottom)?
Probably not.  The base on the supers doesn't really flex much, so you should be ok.  You could always add a thin compressable material under it to fill in the waviness if it bothered you.  Maybe felt?
markrvp
  • NFL Expert
« Reply #3 on: April 28, 2006, 04:32:36 pm »
I don't see how it would affect the performance.  You should be good to go.
tkuper05
« Reply #4 on: April 28, 2006, 09:25:28 pm »
They look fine from up top and they have enough room all around to engage the microswitches.  Just wanted to be sure.
ShinAce
  • Last login:January 16, 2007, 07:38:14 pm
  • Building the unbuildable since 2001
« Reply #5 on: April 28, 2006, 09:51:30 pm »
Why not level it off with shims?
You will regret your crooked joystick later.
An ounce of image is worth a pound of performance.
tkuper05
« Reply #6 on: April 28, 2006, 10:29:50 pm »
I could borrow my friends router and unhook all the stuff to make room to route it but from what everyone says it doesn't seem like it would make much of a difference.
