Author Topic: 2 player CP/4 buttons each/trackball - is this setup decent?  (Read 1892 times)
Ninten-doh
  • Last login:March 31, 2017, 10:37:18 am
  • I promise sweetie, this is my last cab purchase
« on: April 27, 2006, 12:49:31 pm »
Okay, as some of you already know, I'm trying to shoehorn a lot onto a 23 3/4" wide CP.  Original depth is only about 7" (old Frogger CP), but I plan on building it out to at least 9"-10".  Anyway, based on some suggestions, I've cut it down to 4 buttons per player as I don't play fighting games anyway.  Here are the parts...
- Happ optical rotary joystick (will go on the left)
- Ultimarc Mag Stick Plus (will go on the right - non-standard footprint)
- Happ 2 1/4" trackball with mounting kit (plate is 6" x 6")
Attached is a very rough mockup with a 9" depth.  Any issues that you see?  Am I missing out on some classic games if I only go with 4 buttons per player?  Are three button games going to be "comfortable" with this setup?  I'm going to try to make a physical mock up this weekend to try it out, but would appreciate some feedback beforehand.
mhermann
  • Last login:October 04, 2019, 07:10:08 pm
  • We ain't found.........
Re: 2 player CP/4 buttons each/trackball - is this setup decent?
« Reply #1 on: April 27, 2006, 12:55:23 pm »
The only thing I would say is you may want to move the Joysticks and buttons down a little. But besides that I think it is fine for what you are trying to do. I would do a mock up on cardboard to get a better idea of how comfortable it will be.
My 2 cents
ahofle
    • Arcade Ambience Project
« Reply #2 on: April 27, 2006, 04:06:51 pm »
Looks pretty good to me...it might actually be nice to have some space to rest your arms below the sticks and buttons.  I was actually just noticing the other day how much empty space there is below the buttons on an Asteroids cabinet.
Yeah, and definitely mock it up in cardboard first.
Ninten-doh
« Reply #3 on: April 27, 2006, 04:19:29 pm »
Thanks for the feedback guys.  Would I be missing out on any classic/great games if I go with only 4 buttons?  Not into fighting games as I mentioned before.
ahofle
« Reply #4 on: April 27, 2006, 04:42:08 pm »
Defender and Stargate come to mind...
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #5 on: April 27, 2006, 04:47:26 pm »
I say keep the space below the joysticks. I've made the mistake in the past of putting everything too low on the CP. It gets tiresome quickly.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
Ninten-doh
« Reply #6 on: April 27, 2006, 04:53:36 pm »
Forgot about Defender and Stargate.  Guess I'll be stretching to a Player 2 button for Hyperspace!   :P
Noobert
  • Last login:December 15, 2006, 01:27:05 pm
  • Quick! To the Bat-cade!
« Reply #7 on: April 28, 2006, 04:50:05 pm »
Would it work to just use one direction of your joystick horizontal axis as your Reverse button for Defender (since Defender only uses up-down joystick)?  Obviously might disrupt game flow a little.
trcroyle
  • Last login:December 05, 2007, 10:32:05 am
« Reply #8 on: April 28, 2006, 04:54:38 pm »
Heck, you could assign both left and right to reverse, since it would do what you were wanting naturally that way, though you'd be picking up all sort sof bad hibits if you wver played it on the correct setup.
Ninten-doh
« Reply #9 on: April 28, 2006, 04:57:25 pm »
I could swear that's how the Atari 2600 version played.  (Did I just say that?!?!)
Great idea guys!
ahofle
« Reply #10 on: April 28, 2006, 05:17:18 pm »
There was a nice 'hack' in an older version of mame that let you control the ship exactly like the atari 2600 version.  I believe moving the joystick horizontally in the direction you are currently going activated 'thrust' and pressing in the other direction activated reverse and then thrust.  Actually eliminated the need for thrust AND reverse.  It worked REALLY well (I still wonder what Eugene Jarvis was smoking when he came up with those controls heh).  I was dissappointed when they (mamedevs) got rid of it and keep an old version of mame around just for those two games.  I suck at that game enough as it is without having to handle another 2 buttons just for thrust and reverse lol.
« Last Edit: April 28, 2006, 05:19:19 pm by ahofle »
  • Last login:August 18, 2025, 07:06:41 pm
« Reply #11 on: April 28, 2006, 06:24:31 pm »
Your extending the cp down, but what about underneath it? Is all that being extended out?
My opinion is to not use the trackball in this config. The reason why is follow through. When many people play games like golden tee, world class bowling, shuuz and other trackball games they like to roll the ball with their palms. I personally have a big follow through and about broke a finger on my brothers slikstik (the spinner being right above the trackball)
I can understand not having 6 buttons. I enjoy fighters so 6 buttons is a must. So if your going after classics here, what are you doing regarding the 8way/4way?
Ninten-doh
« Reply #12 on: April 28, 2006, 06:24:47 pm »
Ahofle, what version of Mame does that?  That would kick butt!
BTW, thanks for Arcade Ambience!   :cheers:
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
« Reply #13 on: April 28, 2006, 11:35:08 pm »
Ninten-doh
« Reply #14 on: April 28, 2006, 11:52:20 pm »
EwJ - Thanks for the link
Leapinlew - the Mag Stik Plus is a switchable 4 way/8 way.  I'm concerned about the follow-thru on the trackball as well, but it should be okay for everything my wife and I play with the trackball (Centipede, Missile Command, etc.)  We play Shuuz with a crappy mouse trackball now, and we don't seem to use a lot of follow-thru on that.  Golden Tee is definitely out of the question unless I become a lefty.   ;D
ahofle
« Reply #15 on: April 29, 2006, 12:24:57 am »
I use v0.76 for Defender, but I'm not exactly sure when that feature was removed.  That link from EwJ looks like the same thing though.  8)
EwJ
« Reply #16 on: April 29, 2006, 12:39:38 am »
Don't know if that link will be of any use - think it's for the gp32.
Looks like the defender cheat was removed in mame .84u6 by aaron giles.
find a version just previous to that and try it? use -cheat or something?
anyone have further info?
eastbayarb
  • Last login:March 08, 2013, 12:15:06 pm
« Reply #17 on: April 29, 2006, 11:35:56 pm »
Why 2 trackballs? What games use 2 trackballs ?
Ninten-doh
« Reply #18 on: April 30, 2006, 09:21:31 am »
There's only 1 trackball in this config, Eastbay.  Take a look at the pic at the top of the thread.
