Author Topic: Flush mounting a Imperial Trackball  (Read 1506 times)
ZaneMn
  • Last login:March 04, 2019, 11:11:15 pm
« on: February 28, 2003, 02:45:01 pm »
A little help if you will.  I know this has been covered somewhere but I can't readily find it.  I have a 3" Imperial trackball with mounting plate.  I know I could mount the plate on top of my control panel but I want a smoother looking solution.  I was looking to flushmount it so the mounting plate and carridge bolts are under the pelxi.
So I know that I have to route the depth of the plate out on top of the control panel.  How do I hide the bolts?  countersink into the metal plate and use diffrent bolts (other than carridge bolts)?  Would it be strong enough?
Also what bit do I use on the router to carve out the space for the mounting plate and a good place to get it?
Thank you in advance...
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Flush mounting a Imperial Trackball
« Reply #1 on: February 28, 2003, 03:11:57 pm »
