Author Topic: JPAC keeps disconnecting itself  (Read 1060 times)
xteeejx
  • Last login:November 22, 2006, 12:08:19 pm
« on: April 21, 2006, 01:23:45 pm »
Hey all, has anyone had this problem?  After playing on my cabinet for a while ( maybe an hour ) I start hearing that XP 'bing-bong' sound of a device getting unplugged and my controls lock-up for a couple seconds.  If I open the control panel I can see the JPACs self test led switching on and off.
I would assume it was a short, but I tried different USB ports with the same effect and the cable and JPAC are brand new from Divemaster.
I searched here and looked on ultimarc's website but couldn't find anything.  Could it be a software thing?
Any ideas?
-TJ
deadkenndys1105
  • Last login:November 27, 2012, 03:55:05 pm
Re: JPAC keeps disconnecting itself
« Reply #1 on: April 22, 2006, 12:42:17 am »
This happend to me when I was moving it around a lot and unpluging it a lot when i was working with a temp set-up.  I guessing its just a loose conection.  I have the PS/2 i-pac2 so its a tad diffrent but its basicly the same thing.
17 years old and totaly addicted.
blakes
  • Last login:May 07, 2008, 02:36:51 pm
    • http://www.neo-revelation.org/~neotek/arcade
« Reply #2 on: April 24, 2006, 08:11:30 am »
Could you possibly describe the wiring setup that you have?
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
« Reply #3 on: April 24, 2006, 11:06:32 am »
Make sure to see that the USB input thing on the JPAC is soldered correctly. Sometimes they get a bump or bend and the ground will come lose, and when something moves it will unplug and plug back again.
