Author Topic: Mamewah 1.62 issue  (Read 2489 times)
ppilot
  • Last login:January 06, 2020, 01:33:27 pm
Mamewah 1.62 issue
« on: April 19, 2006, 11:25:48 am »
I decided to upgrade from 1.61 to 1.62.  It's been pretty smooth, but one problem I just cannot figure out, and haven't been able to find addressed anywhere.
I made the change on my desktop computer, no problem.  Copied my mamewah directory to a USB key and transferred it to arcade machine #1, no problem.  Transferred to arcade machine #2 and get the following problem.
If I bring up the options menu, there is no category for 'Platform' or 'Theme'.  If I run directly from the USB key, everything works fine.  If I change the option in the mamewah config manually it brings up the different platforms, so it seems to recognize them; just can't find them in the 'options' menu.  I only have one hard drive on the machine, and have tried copying to various places, deleting and repeating, etc. but I can't seem to get it to work.  Is there something on my 'C' drive or in the registry that is mucking this up?
Hoping someone can help.  Thanks!
Re: Mamewah 1.62 issue
« Reply #1 on: April 20, 2006, 06:42:40 am »
Check the attributes of all files/folder within the mamewah folder.  Maybe for some reason it is different on machine #2.
Also, there are a few little bugs I've recently found in the menu, although it shouldn't prevent you doing anything as long as it is properly set up.
ppilot
« Reply #2 on: April 20, 2006, 07:40:51 am »
Thanks Minwah.  The attributes seem to be all in order.  I'll give some more detail in the next few posts:
Mamewah log:
4/19/2006 9:52:58 PM MAMEWAH v1.62 launched
4/19/2006 9:52:58 PM Cursor scheme: Windows default, Arrow: (None), Wait: (None), AppStarting: (None)
4/19/2006 9:52:58 PM Desktop colour: 0
4/19/2006 9:52:58 PM Wallpaper filename:
4/19/2006 9:52:58 PM Display mode: 1024x1280 @ 60Hz, 16 bit colour
4/19/2006 9:52:58 PM Decimal symbol: '.'
4/19/2006 9:52:58 PM Games list read: 01mame-2.lst
4/19/2006 9:52:58 PM Mode 1024 x 1280 @ 60Hz, 16bit colour selected after 1 attempt(s) at 1/2 second intervals.
4/19/2006 9:52:58 PM Layout selected: C:\Vertical mamewah_v162b10\config\01mame\jcrouse\layout.lay
4/19/2006 9:52:59 PM No. joystick devices attached: 2
4/19/2006 9:52:59 PM Ctrlr file selected: C:\Vertical mamewah_v162b10\config\mamewah.cfg
4/19/2006 9:52:59 PM Keyboard enabled
4/19/2006 9:52:59 PM Joystick #1: GPWiz49 enabled
4/19/2006 9:52:59 PM Joystick #2: GPWiz49-2 enabled
4/19/2006 9:53:11 PM Games list read: 01mame-0.lst
4/19/2006 9:53:14 PM Games list read: 01mame-2.lst
4/19/2006 9:53:17 PM Mode 1024 x 1280 @ 60Hz, 16bit colour selected after 1 attempt(s) at 1/2 second intervals.
4/19/2006 9:53:17 PM MAMEWAH quit
Mamewah.ini:
### mamewah.ini (mamewah v1.62) ###
### (Global) Screen-Saver Settings ###
delay                                     300
slide_duration                            3
### Audio Settings ###
enable_sounds                             1
sound_volume                              100
music_path
enable_music                              1
music_volume                              100
### Movie Settings ###
intro_movie_file
exit_movie_file
keep_movie_preview_aspect                 game_aspect
delay_before_movie_preview                2
music_movie_mix                           mute_movies
movie_volume                              100
### Misc Settings ###
emulator_root_path
auto_setup_emulators                      0
theme                                     jcrouse
wrap_list                                 0
remember_current_game                     1
keep_image_aspect                         1
refresh_images                            0
safe_mode                                 0
show_cursor                               0
keyboard_led_states                       -,-,-
lcd_com_port                              1
lcd_settings
exit_action                               choice
maxlogsize                                100000
### External Application Settings ###
startup_app_commandlines
exit_app_commandlines
exit_and_run_app_commandlines
### Settings used by MAMEWAH ###
current_group
current_emulator                          01mame
locked                                    0
ppilot
« Reply #3 on: April 20, 2006, 07:44:18 am »
Some pics of the directory structure:
ppilot
« Reply #4 on: April 20, 2006, 07:47:05 am »
Here's an actual picture of the menu:
« Reply #5 on: April 24, 2006, 05:15:50 am »
You only seem to have one theme (jcrouse), which explains why there is no 'Select Theme' option.  Not sure about the platform tho...
Try re-downloading and extracting (using WinZip) mamewah.exe - some other decompression tools have been known to mess up the exe and cause very similar problems.
I might add something to the log in future to show the enumeration of platforms/list/themes etc. to show if things are somehow being 'missed'.  Also, I need to ensure file attibutes don't play a part.
ppilot
« Reply #6 on: April 24, 2006, 08:01:21 pm »
Thanks Minwah.  Actually, theme shows up under all my other machines.  When I key it, it says 'jcrouse' and 'default'.  Any other thoughts?
« Reply #7 on: April 26, 2006, 04:27:47 am »
I should have asked before...are you using the latest beta (v1.62b10) ??
In short...if you have checked all I've mentioned then I can't think of anything else...all I can suggest is you double check the file attributes etc - have a play and see if it makes any difference.
I'll try to add some extra info to the log for the next beta which should make it easier to diagnose.
ppilot
« Reply #8 on: April 26, 2006, 07:19:23 am »
Yep, 1.62b10.  If I'm understanding you properly, all of the files have the 'archive' attribute set (on all of the machines) so I don't think that's a problem (I'm assuming you were thinking the 'read-only' one was on?).
I guess I'll just wait until the next beta comes out and try it again.  Thanks for your help.
« Reply #9 on: April 26, 2006, 08:05:30 am »
Yes, ensure 'archive' is set, and read-only and hidden are not set.  Sorry can't be much more help until I add some things in...let me know how you get on with the next beta.
