Author Topic: Idiot with a question, Disassembling a top-fire joystick to install it.  (Read 1086 times)
Gatt
  • Last login:February 04, 2020, 08:24:38 pm
Ok,  I've been at this for an hour and I'm not getting anywhere.  Can't figure out how to take a Happs top-fire apart to install it.  Pulled the E-ring but the button assembly is preventing me from pulling the shaft out,  and I can't figure out how to dismantle the assembly.  Already pulled the micro-switches to get at the assembly,  but not having any success.
Could someone knowledgable help me?
NoOne=NBA=
If it's the "Super" top-fire, you have to pull really hard on the disk piece at the bottom that contacts the fire microswitch.
Add a small amount of twist while you are doing it to get the best results.
It is connected to a plastic shaft inside, so don't get TOO violent with it though.
After you've had it apart a few times, it's alot easier.
Look at the exploded view HERE to see how it all goes together.
Gatt
That did it!  Thanks!
Was afraid of trying that before,  didn't want to snap something important.  Much appriciated!
