Author Topic: newbie: check out my cabinet so-far  (Read 3929 times)
daver
  • Last login:April 08, 2018, 08:08:14 pm
« on: April 17, 2006, 05:30:34 pm »
hi all!, well after seeing a neighbor working on a cabinet, I decided to take the plunge, so after about 10 hours of work here is what I have.
http://www.retrospective.us/gallery/main.php?g2_itemId=1551
Let me know what ya think, and any suggestions you might have, thanks!
XtraSmiley
  • Last login:November 02, 2024, 06:07:19 pm
  • Kill the Big Dog
Re: newbie: check out my cabinet so-far
« Reply #1 on: April 17, 2006, 06:04:41 pm »
Having no wood working skills myself, I say great job!  Keep us updated as you progress.
What are your plans for covering it?  Paint?
hearingprotectionBIGDOG@yahooBIGDOG.com
Kill the Dog man.
ahofle
    • Arcade Ambience Project
« Reply #2 on: April 17, 2006, 06:25:39 pm »
Looks nice.  One thing I would suggest is maybe putting a couple additional 2X4s lengthwise under the monitor shelf for both additional monitor support and to help minimze 'swaying' of the entire cabinet.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #3 on: April 17, 2006, 06:26:06 pm »
It looks great but you need to have this thread deleted or moved to the Project Announcement Forum
markrvp
  • NFL Expert
« Reply #4 on: April 17, 2006, 07:50:49 pm »
That certainly wouldn't hurt anything, but what you have will support the monitor fine and when the back is on, it shouldn't sway.
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #5 on: April 17, 2006, 11:32:36 pm »
 :dizzy: :dizzy: :dizzy: :dizzy: :dizzy: :dizzy:
10 hours wow GJ :applaud:
Slow In Fast Out
daver
« Reply #6 on: April 17, 2006, 11:38:31 pm »
sorry for posting in the incorrect group, thats for the tips, I am pretty surprised how the cabinet dosent really sway at all, i have a ton of l-brackets in there, i also found a local dealer, got a HAPP 3" trackball for $80 and a bracket for $11 and 2 ultimate joysticks for $17 they sell on ebay also, really nice guy. I am adding my pic with the trackball and the controls in the CP.
Kangum
  • Last login:February 25, 2018, 07:46:20 am
« Reply #7 on: April 18, 2006, 05:15:05 am »
I like the way its comming out. I cant believe you did all that in 10 hours. I got a kit sitting behind me for well over 3 months and it still isnt even close to done.
PCtech
  • BYAOC is kinda like methadone
  • Last login:December 07, 2019, 09:58:57 am
  • If the magic smoke gets out, it won't work again!
« Reply #8 on: April 18, 2006, 08:16:33 am »
looks like you got more accomplished in 10 hours, than I have in 10 months.   :o
Looking good....keep the pics coming.   :applaud:
Example of what NOT to say at BYOAC
"a working adult playing a video game - pathetic" - freddykruger666
daver
« Reply #9 on: April 18, 2006, 10:01:44 am »
thanks guys, my father-in-law has a table saw, and that really helped me get a lot done faster, i got the plans from arcadeparadise.org the CP has taken me about 5 hours, but I only started this project about 3 weeks ago. So I am very pleased at the progress so far. It wont be as fancy as some of the cabs on here, but for my first I am just getting the general feel of everything.
Havok
  • Trade Count: (+17)
« Reply #10 on: April 18, 2006, 12:32:32 pm »
Great start, however you may want to re-do the control panel buttons - they are a little far from each other. I did the same thing, and once I moved the buttons closer, my fingers thanked me...
daver
« Reply #11 on: April 18, 2006, 12:43:10 pm »
luckily I have some extra MDF so I guess I can experiment with different layouts, I might cut another CP and play around with hole locations, thanks for the advice!
RickDIII
  • Last login:June 03, 2007, 10:18:28 pm
  • Finished 1st Cab!
« Reply #12 on: April 18, 2006, 05:05:29 pm »
Looks great!
The only other thing I might be worried about is with the CP as well.  Looks like you are going to put a trackball in the center?  Hard to tell from the pics, but be carefull that it won't extend past the front inside edge of your cp box...and also that the box is deep enough at the front to hold the whole assembly.
daver
« Reply #13 on: April 18, 2006, 05:29:54 pm »
Looks great!
that pic is with the trackball installed and mounted and sitting in the CP box.
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #14 on: April 18, 2006, 10:07:40 pm »
It's a decent lookin cabinet. I recommend placing the buttons 1 1/2" apart on center especially if you use the capcom 6 layout. This places them perfectly spaced apart so you can reach all of them with no need to look at the panel.
It's 9am. I'm calling it a nite.
daver
« Reply #15 on: April 19, 2006, 01:00:46 am »
thank you for the advice everyone, i definately will try a few different CP layouts, since i have more than enough MDF left over, i just got done putting a coat of primer on, and I just bought a IPAC2 from a user here, so hopefully by the weekend i will at least be able to test everything out!
daver
« Reply #16 on: April 20, 2006, 12:32:34 am »
I added some pics of it painted
psychopanda
  • Last login:August 31, 2006, 01:13:17 pm
    • PsychoPanda's Secret Grotto
« Reply #17 on: April 20, 2006, 10:33:45 am »
The first painted pic, you can see the brush/roller marks clearly. Did those go away with additional coats or is it something you only see in bright light? I'm not at the painting stage yet, so I'm curious.
daver
« Reply #18 on: April 20, 2006, 11:38:23 pm »
that was because of the flash, it dosent look quite that bad, and thats the first coat, one more to go, will take more pics
daver
« Reply #19 on: April 24, 2006, 03:32:22 pm »
ok everything is working, now I have to do some fit and finish items. And move it upstairs  :o I will update pics tonight.
