Author Topic: Neotec monitor dead  (Read 3025 times)
AlexC
  • Last login:May 06, 2012, 05:18:05 pm
  • "Beware, I live!"
Neotec monitor dead
« on: April 17, 2006, 05:11:29 pm »
Got a 25" Neotec monitor (not sure the model) in a NeoGeo 64 (?) machine. It does not power up. I've check the power supply with a multimeter and it works.
I've checked the fuse in the monitor chasis and it's not blown.
So monitor is getting power but nothing, no picture, no static in the screen.
Look all over the chasis and nothing sticks out as being blown or damaged.
Anything else I should try or look for before I take it to a repair place?
Any help is appreciated...
Thanks all.
grantspain
Re: Neotec monitor dead
« Reply #1 on: April 17, 2006, 05:18:27 pm »
i had a recent fault on a neotec on an artic thunder,no picture and a tick from the monitor psu-it was a short circuit horizontal output transistor and one of the poly caps that feed it-check for any burn marks on the caps and meter your h.o.t. q401 and caps c416,417,419,420-my model is a 25e
« Last Edit: April 17, 2006, 05:37:36 pm by grantspain »
Ken Layton
  • Guru
  • Technician
« Reply #2 on: April 18, 2006, 12:50:17 am »
The manufacturer has a good tech support department at www.neotecgraphic.com
They service all of their monitor models too.
