Author Topic: Monitor woes - *SOLVED*  (Read 3245 times)
tkuper05
  • Last login:February 20, 2022, 07:57:24 pm
  • I find your lack of buttons disturbing.
« on: April 15, 2006, 01:16:55 am »
http://www.oscarcontrols.com/degauss/index.shtml
Has anyone here made one of these degaussing coils before?  I don't have any spare monitors to use for parts so I'm going to have to make my own  :'(.  I take it that I get some magnet wire and make a loop 6-8" in diameter and make sure its 3/8" thick then solder on a lightbulb socket and a momentary switch.  My monitor has a degaussing function on the menu and when I select it it does its thing (makes the screen all wobbly) and removes the discoloration but then 2 seconds later there is a click and the discoloration reapears.  I have tested the monitor in a different location to eliminate the possibility that something near might be causing it.  Any help would be appreciated.
« Last Edit: April 19, 2006, 03:35:29 am by tkuper05 »
mj147
  • Last login:November 10, 2024, 08:04:14 pm
Re: Monitor woes
« Reply #1 on: April 15, 2006, 09:12:55 am »
Here are a couple links to making  a "degauser" of sorts , I have tried it with a couple of Hd magnets with great success. One of my monitors doesn't have a degauser and this is how I "fix" em'
http://www.g4tv.com/attackoftheshow/blog/AOTB/post/466253/Screw_This_Degaussing_Drill.html
http://66.102.7.104/search?q=cache:obDIrdibqkgJ:woil.ws/fixmonitor/+magnet+drill+degauss&hl=en&client=firefox-a
Sorry about the long links , I'm not familiar on how to make one word links  ???
mj147
tkuper05
Re: Monitor woes
« Reply #2 on: April 15, 2006, 02:26:34 pm »
Dang, video won't work.  I think I'm either doing it wrong or the magnets I'm using aren't powerful enough.
grantspain
Re: Monitor woes
« Reply #3 on: April 15, 2006, 06:51:10 pm »
personally i feel you may be a nutter,all monitors use pretty much the same degauss set up,so if you are missing your degauss coil then just look around your local tv repair shop skip for a tube with the coil still on and nick it otherwise you will have to degauss your tube every day for the rest of its life :cry:
tkuper05
Re: Monitor woes
« Reply #4 on: April 15, 2006, 08:18:30 pm »
My monitor has a degaussing coil built in that's not the problem.
grantspain
Re: Monitor woes
« Reply #5 on: April 16, 2006, 12:45:12 pm »
whats the problem?
tkuper05
Re: Monitor woes
« Reply #6 on: April 16, 2006, 06:56:04 pm »
My problem is that the built-in degaussing coil isn't degassing.  :(
grantspain
Re: Monitor woes
« Reply #7 on: April 17, 2006, 02:19:01 am »
depending on your chassis(but they all pretty much the same) you will find a 3 legged black or white plastic componant just after the mains fuse,this is called a ptc componant-this is your problem because this componant controls the voltage to your degauss coil
tkuper05
Re: Monitor woes
« Reply #8 on: April 17, 2006, 06:42:48 pm »
When I try to degauss it with the built-in degausser it clears up all the messed up the discoloration, but only for a few seconds before I hear a click then the discolorations reapear in the same spots.  That makes me think that the built in degausser is working.  Would my local TV repair shop have an external deguasser I could rent?
AlexC
  • Last login:May 06, 2012, 05:18:05 pm
  • "Beware, I live!"
Re: Monitor woes
« Reply #9 on: April 17, 2006, 07:23:42 pm »
I use one of these :
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42685
Just hold the trigger and move it around the front of the monitor.
Works like a charm.
grantspain
Re: Monitor woes
« Reply #10 on: April 18, 2006, 12:25:12 pm »
got any speakers near your tube?
tkuper05
Re: Monitor woes
« Reply #11 on: April 18, 2006, 04:39:30 pm »
I've got 2 speakers that came out of a TV above my monitor.  I figure that they should be shielded.  They are mounted just like alot of the other arcade speakers are oriented.
tkuper05
Re: Monitor woes
« Reply #12 on: April 18, 2006, 04:40:37 pm »
I read about using a soldering gun.  I'm gonna try that next I think.
grantspain
Re: Monitor woes
« Reply #13 on: April 18, 2006, 05:13:50 pm »
try moving your speakers away from the tube,this is a common problem and very simple to rectify
tkuper05
Re: Monitor woes
« Reply #14 on: April 18, 2006, 05:22:55 pm »
I've already tried that.  :(
grantspain
Re: Monitor woes
« Reply #15 on: April 18, 2006, 05:32:02 pm »
where exactly on the screen is gaussing problem,if its in the corners then it could be a magnetised bolt,if your tube has been subjected to long term magnetic fields then your proberly correct only a manual degauss would help-but i must say this rare-any chance of a picture?
tkuper05
Re: Monitor woes
« Reply #16 on: April 18, 2006, 06:53:36 pm »
The most discolored area is the upper left corner.  The lower left corner is also discolored.  This is a monitor I got off ebay so I'm not sure what it has been subjected to.
tkuper05
Re: Monitor woes
« Reply #17 on: April 19, 2006, 01:44:57 am »
Man this really sucks.  I tried the soldering gun and it helped a little bit but then powered it off then on and it came back just as bad.  I have no money in my budget to get a new 22" monitor.
tkuper05
Re: Monitor woes - *SOLVED*
« Reply #18 on: April 19, 2006, 03:37:39 am »
EUREKA!!  I took my monitor out to disassemble it to try to see if that would do anything and to double check interference problems.  While I had it out I was playing with the menu options again.  I came across one function called "Adjust Purity".  This changed the colors in the corners of the monitor!!  :laugh2: wooot
