Author Topic: Anyone built a tree house?  (Read 1661 times)
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« on: April 11, 2006, 04:16:47 pm »
Hello,
I have a 3 year old son who loves the outdoors.  I also have a HUGE (read 60-foot) chinese elm tree in my back yard about to get "Topped".  I would like to top it all the way down to about a 10-foot "stump" which would be about 4 foot in diameter.  My question is, can I attach a tree house to that stump using the flat surface of the stump as a base and then just lay floor joyces (sp?) on top of it?  Never built a tree house, and want to make sure I do it right and make it look good so the wife is happy as well.  Thanks in advance!!
ED7
crashwg
Re: Anyone built a tree house?
« Reply #1 on: April 11, 2006, 06:17:37 pm »
Joists!  Some will argue that I'm sure, but joists is plurral for joist as nails is plurral for nail!
Can ya tell I've been annoyed by that before?  :P
As for your question, it's not the way normally done but I'm sure it'd work.  What you should do is find a couple or three sets of branches that are semi-parallel you can atatch two or three joists to and build off of that.
Something like this...
« Last Edit: April 11, 2006, 06:23:43 pm by crashwg »
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Ed_McCarron
« Reply #2 on: April 12, 2006, 02:06:46 pm »
4' diameter?  You could probably build an 8x8 platform on top - it'd only cantilever 2' on each side.  To be safe, run diagonal braces from the floor frame back down to the trunk at a 45 degree angle.  Lag bolt into the tree w/ at least 6 or 8" lag bolts.
Its your kids up there.  Overkill is best.
electricd
  • I'm not a llama!
« Reply #3 on: April 12, 2006, 02:08:48 pm »
Thanks for all the good advice!  Will this tree stump eventually die or what?  I mean how long will this treehouse be safe  up there if built correctly?
Ed_McCarron
« Reply #4 on: April 12, 2006, 02:21:39 pm »
Eventually, sure, the tree will rot.  If its a dense wood, hopefully your kids will be in college before this occurs. :)
Theres dead trees at my parents house that I used for tree houses as a kid.  I'm 34.  The trees are still pretty solid.  Your milage may vary - just check the sturdyness of the thing every now and again.
Stingray
« Reply #5 on: April 12, 2006, 03:06:28 pm »
I have dead trees on my property that were dead when I bought it almost 11 years ago that are still standing.
-S
electricd
  • I'm not a llama!
« Reply #6 on: April 12, 2006, 03:08:26 pm »
Awesome...Im not much of the outdoorsman, but I think a tree house would be something great that we can both enjoy for a long time.  I have him playing pacman now, so maybe I will put a little bartop arcade in there.  I have been looking for an excuse to build one for a LONG time :)
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #7 on: April 12, 2006, 05:19:27 pm »
Good luck running electricity up there!
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
electricd
  • I'm not a llama!
« Reply #8 on: April 12, 2006, 08:26:33 pm »
I thought I would just put a socket somewhere and then use an extension cord.  Don't want the city to think its not a "temporary dwelling"...last thing I want to do is pay taxes on another dwelling!
SithMaster
« Reply #9 on: April 12, 2006, 08:44:36 pm »
make it with an escape hatch and maybe a zip line.  yeah that would be kewl.
97thruhiker
  • Last login:October 04, 2014, 01:55:30 pm
« Reply #10 on: April 12, 2006, 09:53:41 pm »
Wow! a topic on this site that I actually have professional training in.  I'm a forester by profession, went to the University of Florida and got a degree in Forest Resources and Conservation.  You should be fine building the tree house as long as the bole of the tree is currently in good shape (no major rot / animal holes / etc).  The tree stump will lose some of its density over time as it slowly dries but should be structually sound for many years (at least as long as they would have interest in a tree house).  As someone previously mentioned go overkill on the construction considering your kids safety is involved.  Here's a link to a stat sheet on this species
http://hort.ufl.edu/trees/ULMPARA.pdf
Heres an example of an old firetower.  Don't think you want to go that extreme for your kids.
