Author Topic: Quick question regarding mounting a Perfect 360  (Read 1292 times)
phantompower
  • Last login:June 14, 2024, 01:20:45 pm
  • The Game is NOT Over!!
    • MameStation
« on: February 26, 2003, 08:51:09 pm »
Hey all,
Quick question.  I am about to mount two Perfect 360s into a new controller I am building.  Before I take the next step, I would like an opinion on whether or not I need to route a 1/4" groove out from under each of the joystick bases to allow the sticks to sit a 1/4" higher.
I am mounting these into a 3/4" piece of wood.  Would prefer to nto have to route, but, with the three controllers I have built in the past, I have always routed those bases.
Anyway, any opinions regarding the necessary installation precautions for the Perfect 360 joysticks would be appreciated.
Regards,
Chuck
eightbit
  • My cab is never done...
Re:Quick question regarding mounting a Perfect 360
« Reply #1 on: February 26, 2003, 10:41:53 pm »
If your not covering with plexi and you use the taller spacer I would say you wouldn't have to route but its really a matter of personal preference. If you don't route I'd quess its probably going to be 1/8" shorter than if you had used the shorter spacer on a metal panel.
