Author Topic: GroovyGameGear GPWiz49 / gamepad question  (Read 1822 times)
quarterback
« on: April 06, 2006, 11:46:34 pm »
I have a GPWiz49 that I bought to use with a 49-way joystick.  These controllers are "gamepads" rather than "keyboard emulator".  I now want to use it for something beyond my 49-way stick.
It has "23 additional inputs, including 5 that are "shiftable", for conventional Joysticks, buttons or similar switch based devices" I can get them to register in my WinXP/control panel/game controllers window, but I don't know how to map those gamepad buttons to work with MAME.   IOW, how do I get a gamepad button "22" to register as "arrow up" etc?
Do I need 'key2joy' or something like that?  And, if so, what do I need to know about it to make it work? (I've seen the name bantered around but I know nothing about it)
« Last Edit: April 06, 2006, 11:48:46 pm by quarterback »
-- Chad Tower
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
Re: GroovyGameGear GPWiz49 / gamepad question
« Reply #1 on: April 06, 2006, 11:54:17 pm »
not sure if this answers your question but you can press "tab" in mame and set the
player 1 up  to  game pad button 22
then when switch "GP22" is pressed the character will move up.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #2 on: April 06, 2006, 11:54:57 pm »
I used the tab function in a game and just mapped the buttons that way.  Also, for other emulators, most have esc hard coded, (pinmame especially comes to mind), so instead of using joy2key, I'm adding a keywiz and hooking up the escape and pause buttons that way.  I will probably hook up all the pinball buttons through there and the start buttons for poop and giggles.
quarterback
« Reply #3 on: April 06, 2006, 11:57:58 pm »
Ahhhhh... sometimes I can't see the forest for the trees.  What you're saying is that these numerical "gamepad numbers" will register while I'm in MAME as well.
IOW: no need for some intermediate piece of software, I just need to reconfigure MAME to use the GPWiz49/gamepad button-numbers instead of the keyboard key-strokes.   I was over-thinking it.
Thanks y'all!
-- Chad Tower
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #4 on: April 07, 2006, 12:43:13 am »
I would try to hook up your switches to the lowest numbers available, due to some emulators not registering the high joystick number inputs.  Just something I thought you should be aware of.
quarterback
« Reply #5 on: April 07, 2006, 03:13:33 am »
Cool.  I'm only running MAME, but that's good to know.
Well, I got it all hooked up an working.  Next question though, how do I configure MameWah to work now?  It's wants the "1",  "2", "esc" and up/down keystrokes are no longer coming out of my CP.   I scanned through the docs but couldn't find anything.  I know I'm using an old version, is that the problem or is there some easy answer to this?
-- Chad Tower
ppilot
  • Last login:January 06, 2020, 01:33:27 pm
« Reply #6 on: April 07, 2006, 06:40:57 am »
Edit the 'default.ini' file in the ctrlr subdirectory.  Should be pretty self explanatory.
quarterback
« Reply #7 on: April 07, 2006, 12:15:20 pm »
Thanks man.  I had read the crtl.document file in the "docs" folder but though the ctrlr subdirectory was only for setting info for individual games or emulators.  I didn't realize it was also a place for settings that controlled mamewah itself  Sometimes the mamewah docs make me dizzy.  :dizzy:  and this gamepad stuff is all new to me.
But with a little playing around, I'm all good to go.
Thanks again all
qb
-- Chad Tower
Samanai
  • Last login:May 25, 2008, 06:39:35 pm
« Reply #8 on: August 15, 2006, 12:46:46 pm »
I hate to ask a question that I'm sure will have an obvious answer, but I'm stuck and can't find anything in search that has been on point.
I'm using PowerMAME with a Mala frontend, but am just now getting around to installing actual joysticks (the HApps 49 ways) for use with that setup.  I have my GPWiz49 wired up and it registers in the Windows game controller config utility, but I have not figured out how to make it work in MAME.  Once you tab into the controls settings for MAME and select a function to change, should the buttons wired through the GPWiz49 automatically display when pressed (much like a keyboard button would)?
Is there something I have to do enable the use of the GPWIZ49 with PowerMAME?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #9 on: August 15, 2006, 06:01:49 pm »
Did you enable joysticks?  I know official mame disables them by default.
Robin
Knowledge is Power
Samanai
« Reply #10 on: August 15, 2006, 09:03:06 pm »
Bingo!  Every thing is A-OK now.  I knew it was going to be something that obvious.  Thanks!
