Author Topic: What 4-way does everyone use?  (Read 2864 times)
jim_daniels
  • Last login:June 09, 2003, 12:21:22 am
« on: February 26, 2003, 12:35:46 pm »
I've been looking for a decent dedicated 4-way stick for my cab and can't decide what to get.  I like the ultimarc j-stick the best so far, since it has the retro-cool ball-top and is long enought to fit without routing. Shipping kinda bites though, wish i'd have ordered it with my i-pac....
So which 4-ways does everyone else use? Just supers with the actuator flipped?  Anyone got anything they'd sell me?  I'd really like a ball top....
J_K_M_A_N
Re:What 4-way does everyone use?
« Reply #1 on: February 26, 2003, 12:53:39 pm »
I use the Ms Pac-Man/Galaga 20 year stick from happs and I still say it is the ONLY way to go. In my first 2 stand alone cp's I used 4-way comps (I think) and they are NO match for the Ms Pac Man stick. The only problem (for some) is it can only be mounted in a metal cp so you have to either route the wood or make a plate for it. I had a friend of mine make a plate for me. I love it. Good luck.
J_K_M_A_N
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #2 on: February 26, 2003, 03:01:26 pm »
I use the Ms Pac-Man/Galaga 20 year stick as well. A dedicated 4 way is great to have
If you build a frankenpanel, chances are I don't care for you as a person.
eightbit
  • My cab is never done...
« Reply #3 on: February 26, 2003, 03:41:39 pm »
The only convertible 4 way that has decent action in 4 way that I have found is the t-stick sold by ultimarc. The others like the competition and the super when in 4 way mode won't register the diagonals but they still move diagonally.
wee beastie
  • Last login:October 06, 2003, 03:33:02 pm
« Reply #4 on: February 26, 2003, 04:12:54 pm »
I use the j-stick.  Note:  If you go the j-stick route, it can fit in a 3/4 mdf without routing, but it isn't very tall.  It's about the same height as a real Ms Pac stick mounted in the metal (ie: the ball is low).
IMO the j-stick is great.  The only drawback is that it is very loose action.  In other words, you don't need to push very hard to get it to move in a direction.  So, function is flawless, but feel is still different than an authentic leaf sw 4 way joystick
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« Reply #5 on: February 26, 2003, 04:26:53 pm »
I'm using a old style (Leaf) 4 way pacman stick.  Works great! Also gives great feel to the older games, plus no clickety click!
I tried the supers in 4 way, but they didn't respond perfectly for games like donkey kong, although they did work ok.
mikej
  • Last login:February 25, 2003, 02:22:23 pm
    • Lunchpicker
« Reply #6 on: March 04, 2003, 01:58:34 pm »
Resurrecting an old topic here...
Is anyone using the ms pac-man/galaga stick in a wood cp with a lexan overlay?
According to Happs the joystick height is 2.01".  If I put a lexan overlay on top, that still leaves just over 1.75" of joystick.  That seems like enough, but I am wondering if anyone else has done this.
One last question...when installing a lexan overlay, do I take the ball off of the joystick or do I have to drill the hole large enough to fit over the ball?
Thanks,
Mike
Brax
« Reply #7 on: March 04, 2003, 03:15:43 pm »
Thanks,
Mike
Most people use a custom made mounting plate to mount the stick. I routed out a fancy hole for my joystick and mounted it from the top much like a trackball. Either way is acceptable.
A 1 1/4" hole is fine just like the rest of your joysticks. You remove the shaft from the joystick when you mount it just like the others.
Nervous
  • Last login:May 25, 2005, 08:48:50 pm
  • * sigh *
« Reply #8 on: March 04, 2003, 04:17:04 pm »
I like the Happ Super Joysticks.  They can be either 4 or 8 way.
I've used the pac-man/galaga sticks, but they always feel too short.
dhansen
  • Last login:November 28, 2025, 10:41:14 am
  • No Quarters Needed
    • Arcade Stupidity
« Reply #9 on: March 04, 2003, 10:40:22 pm »
I use wico leaf joys...I love 'em (although hard to find these days)
Doug
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
jdjuggler
  • Last login:May 08, 2022, 10:54:37 pm
  • Hurray! I don't have pockets for quarters anyway!
« Reply #10 on: March 05, 2003, 12:08:38 pm »
Hey Brax,
I was wondering if we could see any pictures of your mounting of the 4-way stick.   I'd like to be able to mount mine as high as possible.
Thanks.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #11 on: March 05, 2003, 03:23:56 pm »
Note you can easily increase the spring pressure on the J-Stik if you wish, just unscrew the 4 screws holding the front-plate on, pull out the shaft, take off the circlip and stretch the spring. Re-assemble.
Andy
lightspeed
  • Last login:July 26, 2016, 07:48:35 pm
« Reply #12 on: March 05, 2003, 03:25:59 pm »
I've got Happ's repro Ms. Pac Man stick, which uses microswitches.
 I'm happy with it, but its hard to beat the old leaf-switch style sticks.
jdjuggler
« Reply #13 on: March 07, 2003, 10:50:30 am »
I'm interested in mounting the Ms. Pacman/Galaga 4-way on my CP, but I'm concerned about it being too low.  Will a custom mounting plate bring it up higher?
Does anyone have pics of how this would be mounted without the stock mounting plate?
Thanks.
JD
