Author Topic: Here's my external CP  (Read 3704 times)
Gh0sty
  • Last login:November 17, 2025, 03:43:45 am
  • flying Mame Player
« on: April 05, 2006, 02:04:31 pm »
Hello,
i just wanted to show you my own build Control Panel. On the first Picture you see i have
this two 37" CRT monitors, what i needed was an external sit down panel. Because i use
the monitors also for Racing and Lightguns the plan was to build a CP what can be
dismantled easy, but it have to be strong. Because of new CP's in the future i plan to build
(ie: Track Ball, Spinner) i build the I-Pac4 also into a external Case. Connecting the CP to
the I-Pac4 is done with regular D-Sub connections (25 & 9 pins). This way i can connect
2 external CP's for 3 or 4 Player games if needed and the main reason i dont have to buy
a new I-Pac for every new CP ;)
Now a quick description of the pics, i started to build the CP 1:1 from cardboard, this way
I could find (and instant feel) good positions for the buttons and Joysticks.
The units were then transferred to the wooden plate and the work on the wood started
(bore & saw). A friend of mine build the two racks from aluminium where the plate will be
screwed on with Lock-screws (sp?). In order to hide the Joystick metal plates i bought a
veneer (sp?) and stick them with patex adhesive on the wood. I dont know how to describe
veneer, but its very durably, its like a kitchens sill plate and its availible in many different
colours and textures. Then i prepaired the edges for the t-molding. Next was the underbody
for the cables, it serves also for the whole CP stability. I think the last pictures are
self-describing, but one more note, the two holes in the bottom are made so i can manually
quick change the Joysticks (Suzo 500) to 2/4/8 way mode.
Gh0sty
Re: Here's my external CP
« Reply #1 on: April 05, 2006, 02:07:52 pm »
Gh0sty
« Reply #2 on: April 05, 2006, 02:10:58 pm »
Gh0sty
« Reply #3 on: April 05, 2006, 02:12:16 pm »
finish
PCtech
  • BYAOC is kinda like methadone
  • Last login:December 07, 2019, 09:58:57 am
  • If the magic smoke gets out, it won't work again!
« Reply #4 on: April 05, 2006, 02:42:14 pm »
Looks good, and durable.  Looks like a good fix for what you have.
Looks like a slight bump might knock it over though....do you have problems keeping it stable?
Neat idea!   :applaud:
Example of what NOT to say at BYOAC
"a working adult playing a video game - pathetic" - freddykruger666
Gh0sty
« Reply #5 on: April 05, 2006, 05:15:37 pm »
absolutely no, we play-tested 2 player games for a few hours and its solid like a rock.
The rack is aluminium, but it is heavy, its aprox 0.39 inch thick. Steel would be even
tkuper05
  • Last login:February 20, 2022, 07:57:24 pm
  • I find your lack of buttons disturbing.
« Reply #6 on: April 06, 2006, 09:01:35 pm »
I really like your veneer you put on there.  Where did you purchase it?
Gh0sty
« Reply #7 on: April 07, 2006, 08:58:39 am »
i bought it from a local wood-shop here in germany, they selling everything from/for wood.
I doubt this will help you, but you just have to look for a similar shop in your area.
Unfortunately they mainly sell for bussines only in large quantities. Veneer was only
availibe minimum 3m x 2m. So i still have plenty enough for more CP's ;)
One more note, you can bend veneer easy but not to much, it brakes very easy
you have to be carefull while cuting it.
R
Gh0sty
Gunstar Hero
  • Last login:September 28, 2014, 01:51:17 am
  • Back in action!
« Reply #8 on: April 07, 2006, 09:46:53 am »
I'm digging the legs, they look awesome, and the CP looks like it covers all the bases. Sweet!
