Author Topic: '97 Dodge Caravan Hard to Steer  (Read 7016 times)
ha-Y-n
  • Last login:November 29, 2007, 06:16:07 pm
  • Shaka braddah
    • www.brianDAhawaiian.net
« on: April 03, 2006, 02:50:15 pm »
I asked this question in an automotive forum, and figured I'm signed up here so what the hell.  someone here might be able to help, anyways here gos.
My dodge caravan is super hard to steer, like there is no power steering, i checked the fluids and it is fine, what else could be the problem? ???
Darkstalker
  • Last login:June 27, 2010, 12:55:36 am
  • A legend in my spare time...
Re: '97 Dodge Caravan Hard to Steer
« Reply #1 on: April 03, 2006, 02:54:01 pm »
Does it make a bad whining noise when you turn?  Pump could be dead/dying, belt could also be loose.
Still in the collecting parts and ideas phase of cabinet building.
AtomSmasher
    • Atomic-Train
« Reply #2 on: April 03, 2006, 03:15:43 pm »
The only vehicle I've done serious repair work on didn't have power steering so I don't have any experience with it, but I've had a vaccum leak cause odd problems like that before (caused my power brakes to go out).  Also, like already mentioned, could be the power steering pump.
ha-Y-n
  • Shaka braddah
« Reply #3 on: April 03, 2006, 03:37:46 pm »
not a whining noise, more like an air leak noise, so it might be the pump then?
thanks for the quick response guys, the other forum didn't respond yet :angry:
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
« Reply #4 on: April 03, 2006, 06:40:16 pm »
My wife's van is a 2000?  I think.  We had the whining sound bad.  Dealer replaced a "Power steering resevoir"
Mechanics talk for you got ripped off?  Maybe, but we had a protection plan.
It fixed the problem.
Jacktucky
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
ha-Y-n
  • Shaka braddah
« Reply #5 on: April 03, 2006, 07:23:01 pm »
what's the power steering resevoir?
another thing, i just spoke to my wife and she said that sometimes it turns fine.  when i drove it, it was horrible. I'll check it out when i get home.
thanx for the feedback peeps :notworthy:
« Last Edit: April 03, 2006, 07:24:40 pm by ha-Y-n »
ha-Y-n
  • Shaka braddah
« Reply #6 on: April 03, 2006, 11:15:33 pm »
I test drove it up the road and back and like my wife said the prob only happened sometimes.  I would be driving and the steering wheel would stick, but when i reach a certain point (while turning the wheel) and it would ease up, weird  :dizzy:
belts are fine
is the power steering reservoir the place where you put the fluid?
when the wheel is fully turned it makes a hissing sound
any thoughts
« Last Edit: April 03, 2006, 11:25:30 pm by ha-Y-n »
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #7 on: April 03, 2006, 11:46:00 pm »
Almost sounds like a kinked line somewhere too, from that last post.
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
« Reply #8 on: April 04, 2006, 09:50:02 am »
had the exact same problem on an old peugot here, where it would have power steering then lose it, then it would come back,
turned out to be a cracked hose which had pulled air into the system, the pump would hit air every so often and the stearing would go stiff until it cleared.
The older rangerovers are solid on the steering in cold weather until you have driven it for about 200 yards, (probably due to tired pump)
try replacing the fluid, and check carefuly for leaks.
Clonedsheep
  • Last login:March 29, 2025, 09:59:42 pm
« Reply #9 on: April 04, 2006, 12:50:09 pm »
Hissing: Sounds like damage to your steering column coupler to dash panel seal or valve in the power steering gear. How is the returnability?
No assist: Power steering pump issue. (maybe binding of the sterring column but with the hiss I doubt it)
I doubt it is the lines. I would say you would have to replace or rebuild your power steering pump.
I am by no means an expert yet. I am taking my A4 ASE exam in may. Let me know if I am right.
The king of 1/2 done projects
ha-Y-n
  • Shaka braddah
« Reply #10 on: April 04, 2006, 01:27:54 pm »
My boss also mentioned this
the hissing sounds like its coming from the right side of the van where the pump is, does that matter?
returnability?
is that when the wheel turns back?
atfer work I'll see if i can check the hoses.
thanx again peeps, i appreciate the help
Stingray
« Reply #11 on: April 04, 2006, 01:53:42 pm »
Sounds like the PS pump to me too.
-S
Clonedsheep
« Reply #12 on: April 04, 2006, 02:39:49 pm »
the hissing sounds like its coming from the right side of the van where the pump is, does that matter?  Yes. If you are sure of the location and the pump is bad you would lose assist.
If the sound is from your power steering box or rack and not the pump.  Where the steering column meets the rack. Best way I could put it.  That makes the hissing sound.
returnability?
is that when the wheel turns back? yes after the turn
atfer work I'll see if i can check the hoses. = If it was a hose you would lose fluid and you would get foaming in the pump. (whine when turning) You said the fluid level is fine and power steering lines deal under a buttload of PSI.
Check out this place (Clarks) for discounted rebuilt and new parts. They are based in LA California. Phone skills need work but damn the prices rock. 562-630-1811
ha-Y-n
  • Shaka braddah
« Reply #13 on: April 04, 2006, 06:45:52 pm »
If the pump was bad then wouldn't i feel the problem all the time?
Clonedsheep
« Reply #14 on: April 05, 2006, 01:33:10 pm »
  The control valve assembly sometimes stick and are known to cause intermittent problems. That attaches to the pitman arm and directs flow of power steering fluid. Pretty easy fix I believe.
Sounding less like the pump to me but I don't have enough Exp. points to really be sure.
certain point (while turning the wheel) and it would ease up, weird...this is where I think it is part of your control valve. As you turn the wheel the pressure in the power steering increases.
I am going to look it up on Alldata when I go to school tonight. 2000 Dodge Caravan. Please give me the model and engine size.
ha-Y-n
  • Shaka braddah
« Reply #15 on: April 05, 2006, 01:45:29 pm »
Thanks clone and everybody else, i appreciate the help.  It's a 1997 dodge caravan 3.0 liter, v6
thanx again
is the control valve assembly part of the steering box?
« Last Edit: April 05, 2006, 01:58:41 pm by ha-Y-n »
ha-Y-n
  • Shaka braddah
« Reply #16 on: April 06, 2006, 03:49:34 pm »
Well we gave the van to a good friend.  Initially I was going to try and fix it before we gave it to him but he really needed a car.  I gave him the list of possible fixes and he said he'll try them out.
If anyone thinks of anything new I'd appreciate it alot.
thanks again everyone you've been a big help.  Once he's got to fixing it, I'll post back with results
thanx  :notworthy:   :applaud:
bRiAn
