Author Topic: My Own Arcade Controls  (Read 1605 times)
BoomTrigga
  • Last login:July 14, 2003, 05:52:10 pm
« on: February 25, 2003, 10:08:51 pm »
I have a few questions that I was hoping someone knowledgeable could answer for me. I'm planning on building an arcade control unit to use with MAME 32 and I was curious of three things
1.)  How many buttons are used maximum in each of the 4 modes of games on MAME.  Namely, the maximum number of buttons used in a 1 player, 2 player, 3 player and 4 player game.
2.)  What would you suggest I have in/on this arcade control panel?  Including the number of buttons per joystick (I plan on making it a 4 player panel)
3.) What type of joystick and trackball should I have and from where?
I also have a question about the light gun games.  What type of "light gun" can I use to play the shooting games on MAME?  I saw two types on wicothesource.com, but I'm not sure if they will work with a PC based homemade arcade unit.
Generic Eric
Re:My Own Arcade Controls
« Reply #1 on: February 25, 2003, 11:41:13 pm »
If I recall,
player 1 & 2: 6 buttons each (typical fighter layout) or 7 buttons each (you may have seen this on some examples, some people like to blend a Neo Geo arc layout into a Capcom layout.
player 3 & 4: 4 buttons each (thats the max used in a game from what I have read)
The best advice you will get on the acutal button placement is to take a piece of card board and use that as a means to test.  that way all you waste is cardboard.
edit
http://www.oscarcontrols.com/joycompare/joyreview1.shtml
« Last Edit: February 25, 2003, 11:42:34 pm by generic_eric »
eightbit
  • My cab is never done...
« Reply #2 on: February 26, 2003, 11:33:07 am »
There are only a few games that use more than 4 buttons for p3/4. Most 4 player games use 2 or less. Depends on what you want to play and how important it is to you.
