Author Topic: Question to RandyT or anyone else in the know. USB 1 or 2  (Read 1976 times)
MYX
    • MYX Digital Blog
« on: March 29, 2006, 04:05:52 pm »
I am about to start hooking up my stuff shortly and am wondering if it maters if I use USB 1 or 2. I know that all LED voltave is supplied through the USB. I did not know if the 1 or 2 mattered. the USB on my motherboard is USB 1 but can easily buy a card if need be.
Also is there a better usb hub to buy?
M    Y    X
Tiger-Heli
    • Tiger-Heli
Re: Question to RandyT or anyone else in the know. USB 1 or 2
« Reply #1 on: March 29, 2006, 04:18:25 pm »
I'm assuming you mean USB 1.1 or USB 2.0.
From what I've read on the PowerMAME threads, the LED-Wiz is a USB 1.1 device, so you should do better with that setting, but if you get the latest (next - 104.2.0 - not released) PowerMAME it should work with any 2.0 device or hub.
Nvidia 2.0 and some Intel motherboard controllers were having problems.
Hard to say on hubs.  I've used cheap Adesso 4-port hubs in both 2.0 and 1.1 versions.  The 2.0 gave me fits under Win98 on one machine and seemed to work fine on another machine with the same brand/model motherboard  :banghead:
RandyT
    • GroovyGameGear.com
« Reply #2 on: March 29, 2006, 04:58:09 pm »
If you are 1.1 already, don't bother going to 2.0 for controls.  HID devices are "low-speed" USB devices and won't benefit from 2.0 at all (at least in a practical sense.)
Also, If you have to use 2.0, use a 1.1 hub just to avoid potential difficulties.
RandyT
hanelyp
  • Last login:January 10, 2009, 11:08:19 pm
« Reply #3 on: March 29, 2006, 06:12:30 pm »
...HID devices are "low-speed" USB devices and won't benefit from 2.0 at all (at least in a practical sense.)
-Most- HID devices are low speed, 1.5Mb/s.  The specs allow for full speed, 12Mb/s, and there are advantages for devices such as arcade keyboard encoders with lots of buttons.  High speed USB 2.0 isn't much use for HID.
MYX
    • MYX Digital Blog
« Reply #4 on: March 30, 2006, 10:37:52 am »
great this will save some moolah.
M    Y    X
« Reply #5 on: March 30, 2006, 10:52:29 am »
I'll second this point, since this very issue caused me some headaches...
RandyT
« Reply #6 on: March 30, 2006, 12:09:17 pm »
Ok, let me re-phrase that.
While the spec allows for "full speed" HID devices, I have never seen one in my travels.  My HID devices and the current lot of similar HID devices from other vendors are also "low speed" devices.  Added to that, given the penchant of commercial controller manufacturers to save money when producing items like joysticks, mice, keyboards, etc  and the fact that "full speed" controllers are more expensive than their low-speed counterparts, not to mention that OS support is limited to non-existent without special drivers for anything else, make it likely that things will be that way for a while to come.
And since the 1.1 spec handles everything but "high speed" devices anyway, 1.1 is the way to go for your HID controls to avoid any potential difficulties.
RandyT
