Author Topic: 3" Diameter White High Lip Trackball  (Read 4831 times)
Kane
  • Last login:June 06, 2023, 08:05:47 am
  • What?
« on: February 25, 2003, 10:04:59 am »
If I bought one of these can I mount it in 3/4" wood or do does it need to be mounted in a thin metal?
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
Re:3" Diameter White High Lip Trackball
« Reply #1 on: February 25, 2003, 10:10:57 am »
thin metal.
it's called a trackball mounting plate. Then you mount that to your 3/4" wood.
If you build a frankenpanel, chances are I don't care for you as a person.
TazMan
  • Last login:January 26, 2025, 03:30:01 pm
  • It's no easy being green.
    • What is the MAMEtrix?
« Reply #2 on: February 25, 2003, 10:11:50 am »
Are you referring to the Happ 3" Diameter High-Ball Trackball?
If so, I have on mounted in my cabinet (5/8" plywood) - I also bought the mounting kit (plate and screws).
« Last Edit: February 25, 2003, 11:03:35 am by TazMan »
eightbit
  • My cab is never done...
« Reply #3 on: February 25, 2003, 10:51:14 am »
Mines not a high lip and I didn't use a mounting plate at all.
I cut a hole to exactly fit the TB housing. Then I dissasembled the trackball and lined up the trackball housing to be flush with the CP and screwed into the side of the plywood from inside the trackball. I then covered the CP in vinyl and reassembled the trackball.
Kane
  • What?
« Reply #4 on: February 25, 2003, 11:42:56 am »
Thanks guys, that's all I need to know. I wasn't sure if it would work in 3/4" wood. :)
dac
  • Last login:May 27, 2005, 10:13:46 am
  • newb
« Reply #5 on: February 25, 2003, 01:45:15 pm »
TazMan,
nice picts of the cp,
3/4" wood, how much(deep) did you route out for the mounting kit?  and does anyone have a template of the football shape anywhere?
Dac
TazMan
« Reply #6 on: February 25, 2003, 01:53:32 pm »
TazMan,
Thanks Dac.
I used 5/8" plywood and if memory serves correct, I routed 1/16" of an inch for the mounting plate - don't quote me on that, I just measured the depth by setting the plate on the router and adjusting the bit to match - traced the outline of the plate and routed away.  As far as the football shape goes - again, I laid the football on the cp and traced around it - not right on the edges, just roughly followed the shape and then broke out the jig saw.
« Last Edit: February 25, 2003, 01:54:22 pm by TazMan »
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: February 26, 2003, 04:01:13 am »
The happs high lip model can be mounted on 1/16" (with spacer) or 3/16" (without spacer) thick panels.  3/16" thick wood is not strong enough.  So metal like everyone said before.  I think the happs high ball model is the same, but I know the old style only mounted on 1/16".  Of the other trackballs I tried, the wico 3" is 1/16" only, the betson/imperial 3" is 1/16" & 3/16" like the high lip.
The happ mounting plates are 1/16" thick and very easy to use.  TazMan routed ~1/16", but the black texture on top probably made him adjust the bit a fraction deeper.  I routed exactly 1/16", and the textured plate looks like it is still "puffing out" a little.  I suggest doing it like TazMan did.
Robin
Knowledge is Power
Brax
« Reply #8 on: February 26, 2003, 07:21:05 am »
Here's a fast little router tip to adjust your cutting depth to EXACTLY the thickness of the material.
-Put the mounting plate on a flat table.
-Put your router face on the mounting plate but have the bit hanging off the edge of the mounting plate.
-Lower the bit until it hits the table. That's it. Your depth is set.
Now when you cut your countersink for the mounting plate the depth will be PERFECT.
« Last Edit: February 26, 2003, 08:33:35 am by Brax »
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #9 on: February 26, 2003, 10:47:50 pm »
Yes, much better way.
My plain, unpainted, zinc mounting plate is exactly 1/16", and fits the routed hole prefectly.  I think I measured like you discribed with the zinc plate and assumed it would be fine with the textured plate.
BTW, if I do it again, I'd use a plain zinc plate, route the correct way as you discribed, and cover the cp with a printed vinyl sheet (thus no need to spend $1 more for the textured plate).
Robin
Knowledge is Power
