Author Topic: WinUAE Config Creator v1.0  (Read 3622 times)
headkaze
  • 0x2b|~0x2b?
« on: March 28, 2006, 04:10:09 pm »
UAE Config Creator v1.0 - By Headkaze
Made for TOSEC collection...
This program will take a collection of ROMs and create uae configuration files for them based on a single uae config file. It will attempt to place disk series into floppy0 to floppy4 and in disk swapper. Press END+1-0 to swap disks in emulator.
Strange things happen in WinUAE, it seems to cut off long file names of adf files in the floppy drives. Must be a bug.
The program detects multiple disks by removing file characters after the first "(". This is how it matches file names. Most of the TOSEC collection works this way.
Quick instructions to how this works:
1. Create a config file in UAE with the setup you want and save
2. Edit the uae config file in a text editor and add [WinUAE] to the start of the file
3. Use my program to point to your config file, ROM directory and output directory
4. Select "GO" button
!!!PLEASE NOTE!!! You must add [WinUAE] to the start of the config file! This is because I use standard Ini file functions to write the ini files.
Download from here
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
Re: WinUAE Config Creator v1.0
« Reply #1 on: March 28, 2006, 04:40:59 pm »
Whats the difference between yours and jcrouse's here?
http://www.emuchrist.org/cpviewer/winuaegc.htm
Cheers,
Brad
headkaze
  • 0x2b|~0x2b?
« Reply #2 on: March 28, 2006, 07:04:11 pm »
Mine handles multiple spanned disks, jcrouse's dosn't. In other words if you have to insert a second disk you have to go back into the config to mount the extra disk(s). Mine also places the first 4 disks into the first 4 floppies.
Brad
    • www.emuchrist.org
« Reply #3 on: March 28, 2006, 07:51:54 pm »
Gotcha...Good work =)
Cheers,
Brad
