Author Topic: j-tron chassis samsung tube dead help needed  (Read 1778 times)
jan25th
  • Last login:September 11, 2025, 10:15:20 am
  • Long time lurker
    • forum.arcadecontrols.com/index.php/topic,147244.0.html
« on: March 28, 2006, 12:22:27 pm »
Hi,
I have a MsPacman in a generic case with a 3rd party marquee (read cheap) that has died. I wasn't there at the time but was told that when it was plugged in the monitor flashed then went blank. The monitor did have "issues" prior to its demise, the edges were wavy. I have since gutted it for the coin door and 19" monitor with the hopes of resurrecting the monitor.
The monitor tube is a Samsung model #510UXB22  and the chassis is labeled
J-TRON Model 1901.
I am hoping that a cap kit of some sort will fix the monitor and then I plan on using it in a mame cocktail cabinet. Any advice would be appreciated.
Thanks,
Barry
« Last Edit: March 28, 2006, 04:49:18 pm by jan25th »
Ken Layton
  • Guru
  • Technician
Re: j-tron chassis samsung tube dead help needed
« Reply #1 on: March 28, 2006, 05:33:52 pm »
I've never heard of that brand/model monitor. A capkit would be a good place to start, but I don't think you'll find one for that one. Zanen Electronics will assemble a kit if you send them a schematic though. Bad capacitors can cause the monitor to falsely shutdown intermittently (or more often). It would be a good idea to also inspect the monitor chassis for bad solder joints.
jan25th
  • Long time lurker
« Reply #2 on: March 29, 2006, 03:36:57 pm »
Thanks Ken,
I don't have a schematic so I can't go down that road.
How about buying a new chassis? Is that too specific to the
tube or would I be able to match something?
Thanks again.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: March 29, 2006, 06:11:46 pm »
Visit this site to learn how to check your tube and yoke to determine the correct replacement chassis to order: www.8liners.com/datatech/monitor.html
