October 15, 2025, 05:52:52 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Video Games
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Arcade Collecting
Miscellaneous Arcade Talk
Is my Ikari Warriors PCB dead? Help needed.
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Is my Ikari Warriors PCB dead? Help needed. (Read 3188 times)
vib_ribbon
Trade Count:
0
Full Member
Offline
Last login:August 21, 2014, 06:01:28 am
board - check, joysticks - check, adapter - check
on:
March 24, 2006, 04:33:41 pm »
Hi...
I bought this board a while back and haven't been able to test it until now.
I made my first JAMMA adapter for it, it seemed straight forward enough...
However, when I plug it in, I get a picture like this:
there doesn't appear to be a graphics test switch on the board:
http://www.mikesarcade.com/cgi-bin/spies.cgi?action=url&type=dip&page=IkariWarriors.txt
the board is a bit dusty, but no more than other boards i've had in the past.
could it be:
a/ the board is duff
b/ bad dip switching (i have checked)
c/ bad JAMMA adapter (i made myself)
d/ something else?
please help me, i wanna play this so bad. =(
thanks.
Logged
grantspain
I personally prefer "bog trotter"
Trade Count:
+1
Full Member
Offline
Last login:August 16, 2025, 04:42:10 am
Re: Is my Ikari Warriors PCB dead? Help needed.
Reply #1 on:
March 24, 2006, 04:50:37 pm »
If you got 5,12,-5 and common in the right place it ain't your jamma,it looks like a graphic rom fault,but check your 5v is good at the jamma(about 5.10v),make sure all you dips are off,and check eprom and board connectors are home correctly.
Logged
vib_ribbon
Trade Count:
0
Full Member
Offline
Reply #2 on:
March 24, 2006, 04:56:17 pm »
sorry, one thing i forgot to mention, is that it's running off a small supergun unit with a small PSU... could that make a difference? other games seem fine on it though.
thanks. i'll check the connections you've mentioned.
Logged
vib_ribbon
Trade Count:
0
Full Member
Offline
Reply #3 on:
March 26, 2006, 11:15:06 am »
i checked all the removable ROMs and all the contacts seem strong.
however, i've come to understand that the supergun i'm using does not supply -5 which i'm guessing the gameboard requires when i put together the JAMMA adapter.
is it then a safe assumption to make that this is the cause of the problem? how can i find out for sure that the game requires -5 ?
any help would be appreciated. thanks.
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Reply #4 on:
March 26, 2006, 12:29:49 pm »
-5v was mainly used for sound applications,you need an edge connector pinout of your ikari board to be certain.
Logged
vib_ribbon
Trade Count:
0
Full Member
Offline
Reply #5 on:
March 26, 2006, 02:58:56 pm »
hi grantspain,
thanks for your response.
that's what i mean, it does. when i made the JAMMA adapter, i had to wire the -5VDC pin from the 22/44 edge connector from Ikari Warriors to JAMMA. so even though it might be for sound, could it still have this effect on the game if it's not supplied by the supergun?
sorry, newbie here.
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Reply #6 on:
March 26, 2006, 03:11:20 pm »
The jamma connector was introduced as an industry standard connector,wether your board needed -5 or not did not matter as the board edge connector would control that,now there is a possibility that -5 could be needed for the graphics therefore you could have a problem with it disconnected(i think -5 should be on pins 5&e),don't know what a supergun unit is,but i would always have a good switch mode psu running the jamma because of load requirements and voltage overload/short issues.That psu you have running it at the moment don't sound man enough for the job.
If you had all your voltages correct and i saw that fault then i would put it down to very low 5v or a graphic rom fault.
Logged
vib_ribbon
Trade Count:
0
Full Member
Offline
Reply #7 on:
April 03, 2006, 03:05:14 pm »
thank you grantspain, i got a new supergun with -5VDC and like magic the game now works! (abeit some very small graphical glitches)
thanks again.
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Reply #8 on:
April 03, 2006, 05:39:38 pm »
looks good to me,if you have further graphics problems just check your +5v at the jamma (board side) ,you need about 5.10 or slightly less-anyway congrats on getting it working,ikari is a truly classis game and i hope you have many happy hours playing it
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Arcade Collecting
