Author Topic: Drilling holes in custom CPO?  (Read 2065 times)
Moby Ick
  • Last login:February 12, 2007, 12:41:24 pm
« on: March 20, 2006, 10:23:35 pm »
So I'm designing a custom CPO and was wondering how you cut the holes? Once it's stuck to the primed MDF, can you just use a forstner bit to cut through both, or do I have to cut the holes first?
I don't look forward to aligning it after the fact?
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
Re: Drilling holes in custom CPO?
« Reply #1 on: March 21, 2006, 04:22:43 pm »
Depending on the material I guess.  I've always found it very easy to hold the CP up to the lights while holding the overlay on it.  This way I can see where the holes are (they slightly light up the CPO).  If the material is too thick or maybe has a better print this might not work.  It's always worked for me however.
Then I can glue it down.  Once it is down you can cut the holes with an exacto knife using the holes as a guide.
Next I'll be on fries, and that's when the big money starts rolling in.
Nannuu
« Reply #2 on: March 21, 2006, 04:41:51 pm »
Oh, or you can hold it up against the window.  It's easier to hold and move the CPO around that way.
Or you can feel the button holes through the CPO.
Funny, I have no idea how other people line theirs up?  I never create CP edges on my artwork.
motorfish
  • Last login:September 30, 2009, 03:35:08 am
« Reply #3 on: March 21, 2006, 05:29:30 pm »
I always print targets on my CP overlay artworks to ensure that they'll be perfectly centered.
- Dan
Have you paid your dues Jack?......Yessir, the check is in the mail!
Moby Ick
« Reply #4 on: March 22, 2006, 01:10:01 pm »
Think I figured out a solution.
I printed white 1-2 mm dots at the exact center of the buttons on the CPO. I'm going to hold the cpo over the MDF, drill through each dot, pull of the CPO, then use the dots to center my Forstner drill bit and drill the holes.  If I trim the MDF a bit first, I should be able to line it up afterwards perfectly, and just punch through the holes with an exacto
JLR2000
  • Last login:December 28, 2025, 10:50:05 pm
  • There is NO Sanctuary...
    • WWW
« Reply #5 on: April 02, 2006, 08:49:05 pm »
Yeah, for my CP I designed it in Visio, using "+" marks for center points.  Lined it up on my CP board, taped it down and then used a hole punch (nail set or awl will work too) to mark the center points.  Then removed and saved the CP paper template and drilled away.....it worked out extremely well for me.
Good luck.
