Author Topic: matching a chassis with a monitor  (Read 1622 times)
donwerr
  • Last login:September 01, 2006, 02:48:15 pm
  • I want to refurbish older games
« on: March 20, 2006, 06:24:10 pm »
you'll be able to tell i'm fairly new at this by the question that i ask.  how do you determine what kind of chassis to use for a monitor?  i have a 25" monitor with an old A-one chassis model am-0316...would it be better to have the old chassis rebuilt or get a new one of a different manufacturer?  i'm not sure what chassis can be used on which monitors
Ken Layton
  • Guru
  • Technician
Re: matching a chassis with a monitor
« Reply #1 on: March 20, 2006, 06:55:13 pm »
Probably your monitor only needs a capkit. You can get the correct kit for your monitor from good old Bob Roberts. Cost is around $8.
If you decide to buy a replacement chassis then you should visit www.8liner.com/datatech/monitor.html to learn how to test your monitor for compatibility & to determine the correct replacement chassis to order.
Replacement chassis typically cost $65 to $95 depending on model & tube size.
A replacement monitor will cost you over $350 plus shipping for a 25".
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #2 on: March 21, 2006, 01:37:39 am »
Hey Ken, is it possible to switch  a chassis between different size monitors of the same model #?  For instance if a person had a chassis off of a 19" 7000 series wells, could he put it on a 25" 7000 series?
Ken Layton
  • Guru
  • Technician
« Reply #3 on: March 21, 2006, 01:57:59 am »
Remember the 19" k7000 was made in two versions: one for 8 pin (22mm diameter) picture tubes and one for 10 pin (29.5 mm diameter) necks.
The 25" version uses a 10 pin neckboard and the main board is "P538".
If you had a 10 pin 19" chassis you could temporarily stick it on a 25" tube k7000 for testing purposes only. Remember that the 19" chassis was designed to generate an image properly sized for a 19" tube.
Popcorrin
« Reply #4 on: March 21, 2006, 10:47:18 am »
Thanks again, Ken.
