Author Topic: tv problem...  (Read 1359 times)
penguinkj
  • Last login:April 29, 2009, 10:03:14 pm
tv problem...
« on: March 18, 2006, 03:18:48 pm »
  i'm running my setup out of a nvidia 2 card via a "ultimate XP pro" pc to video component and have it currently running on both a pc monitor and a RCA tv (no svideo, using component)... although i have mame working for the most part, there are some games that play perfect on the monitor but give me a test pattern on the tv, i have tried to mess around with the display settings but have had no success, the strange thing is the games that dont work for the most part are older 1980s games...  any ideas or help would be much appreciated, karen j.
ArtMAME
  • Last login:August 05, 2020, 12:59:17 pm
  • Hey where the ARCADE MACHINES at???
    • Art's Arcade Lab
Re: tv problem...
« Reply #1 on: March 20, 2006, 05:40:14 am »
Since you are a newbie, I will take it easy on you. ;)
A few things you could try:
Use extended desktop mode in Windows.
Set your TV resolution to 640x480, the monitor resolution can be whatever.
Make the TV your primary display.
Set the resolution in each game to 640x480.
Beyond that, I do not know what else you could do without knowing what you have tried already.  If you could post a little more specific information maybe we could find the problem.
Some information that may be helpful in solving the problem would be the following (you don't have to answer them all, I will try to list them in order of relevance):
What display settings have you played with already? (most important)
Which games specifically don't work on the TV?
What revision of MAME are you running?
Are you using VGA to component adapter or DVI to component adapter?
What kind of hardware are you running? (CPU speed, amount of memory, etc)
What model video card are you using?  Are your video card drivers updated?
Are you using an updated ROM set?
I am not trying to be harsh or anything.  It's just that we need a little more information.  We would love to help you out but it is hard to diagnose any problem with not enough information.  I could tell you to try this or that, but I do not know what you have tried, so I may be telling you something you have done already.
Please reply and let us know if it worked or not, and if it did, how you solved the problem... :)
"Klaatu. .. Verada. ...... Necktie...Nectar...Nickel..."
