Author Topic: dimensions for perfect 360?  (Read 839 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« on: March 14, 2006, 12:01:20 pm »
what are the mounting dimensions for the perfect 360?  what joystick has similar dimensions?
I b**ch. People listen!!
blakes
  • Last login:May 07, 2008, 02:36:51 pm
    • http://www.neo-revelation.org/~neotek/arcade
Re: dimensions for perfect 360?
« Reply #1 on: March 14, 2006, 01:02:50 pm »
It should be the same as all other similar joysticks like the Xarcade joystick.  Check out http://www.retroblast.com/reviews/joysticks/happsp360.html for a review where they discuss the installation.
Havok
  • Trade Count: (+17)
« Reply #2 on: March 14, 2006, 01:17:31 pm »
Keep mind also that the joystick mounts with the contacts pointing right, so make sure if you are planning this in Visio, or whatever, that the joystick looks like this:
(Poor attempt at ascii art) Most of the templates I have seen require the joystick to be rotated 90 degrees, if it is a P360...
squirrellydw
« Reply #3 on: March 14, 2006, 01:29:58 pm »
similar to the HAPP competition??  I can't seem to find any dimensions on it.  I saw the review also and didn't see it there unless I missed it
miles2912
« Reply #4 on: March 14, 2006, 03:56:12 pm »
Check out
http://webpages.charter.net/rbecker5/files.html  about halfway down is a joystick template in MS Word.  Forget the buttons and rotate the template 90degrees and there you go.  It is the same one that I used to mount my P360's.
Don
