Author Topic: AtomicFE: [updated] ARCADES Plug'n Play module! (Includes MAME and Zinc)  (Read 1877 times)
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Hi ,
a new great module from Angelscry is on line. This module dedicated to Arcade Machine is built around MAMEPlus 0.104u4 and Zinc 1.1 .  the Module detects itself what is the best emulator to run the game!
There is only one list on the screen with your roms , and if you chose a rom runnable with zinc, zinc will be used if not Mame will be used.
this is the first version of the module. It will be improved soon. On this version as it don't use gamelists yet, if you have a full romset  the module could be slow to load.
« Last Edit: March 13, 2006, 05:46:40 am by youki »
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re: AtomicFE: New ARCADES Plug'n Play module! (Includes MAME and Zinc)
« Reply #1 on: March 10, 2006, 07:14:19 am »
Now that's what I'm talking about. I want a module that takes it further and picks the right version of MAME and/or Raine.
youki
    • Atomic Front End
« Reply #2 on: March 10, 2006, 08:03:01 am »
It is doable but we need a complete list that describes what game run better with what.  We don't have time to try each game with each emulator version!!!
We are studying the possibility to include nebula to this module for NEOGEO games. Not sure it 's worth it. MAME seems good  enough for NEOGEO Games.   what do you things guys?
youki
    • Atomic Front End
« Reply #3 on: March 13, 2006, 05:46:06 am »
Module Arcade UPDATED!
Now , it uses gamelist , so it will be fast to load even if you have a full set of rom!  :)
Few others improvement are in too.
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
Thank God....
I thought that the world of Frontends is just enough...you have done a remarkable job...Now most of other Frontend creater will follow your track...
Exellent work... :)
sWampy
  • Last login:February 02, 2010, 04:23:40 pm
Gameex has done this for quite a while.
youki
    • Atomic Front End
AtomicFe is able to do that since his first version far before GAMEEX.  That module uses just a feature include in Atomic Engine.
I think you can not imagine what the Atomic Engine can really  do yet...   I'm just busy working on configuration tool and solution to make that power accessible to a newbie.  And as i don't have lot of time. it comes little by little.
The best is still to come!  ;)
sWampy
Don't get me wrong, I like your frontend.   I was just pointing out that it had been a standard feature of gameex for a long time.  When you setup mame, it has an enable zinc and a zinc.exe drop down.   I just didn't want the comment about now everyone was going to copy AtomicFE to go totally uncontested.
