Author Topic: Adhesive backed CP overlays and MDF...?  (Read 2249 times)
somunny
  • Is it hot in here?
« on: March 09, 2006, 10:40:38 pm »
I'm wondering if anyone can tell me their experiences with applying adhesive backed control panel overlays to MDF.  Do they stick well?
I'm asking because I'm considering whether I should just stick the overlay to the cp or sandwich it between the wood and some Lexan.
Any help would be greatly appreciated.
Steve
btw, the overlay is from mamemarquees.com if it makes a diff...
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Re: Adhesive backed CP overlays and MDF...?
« Reply #1 on: March 09, 2006, 10:49:07 pm »
If you prime the mdf, that will go a long way.  I also used super77 spray adhesive for added stickiness.  Did you read the paperwork that came with it?
somunny
« Reply #2 on: March 10, 2006, 12:02:34 am »
[best Ted Kennedy voice] Paperwork?  Err, uh... err, uh...
[Scurries off to recycle bin]
Thanks Mccoy.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #3 on: March 10, 2006, 07:28:39 am »
I always use a layer of Lexan or Clear PVC type material over the top. Even though you don't have to do it, it does protect the artwork and the finish. If you spent money on this CP overlay, why wear it out when you can replace the lexan in a few years time.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
« Reply #4 on: March 10, 2006, 07:38:26 am »
I used a white oil-based primer ( two coats) and let it dry for a week before applying the graphic overlay.  It has not lifted at all.  I also use the T-Molding that has the lip that graps wraps around the edge and slightly over the edge of the plexi-glass.  It makes for a very nice finish.
John
Galaga... Was there any other game?
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #5 on: March 10, 2006, 08:12:43 am »
Best Regards,
Wouldn't it be just about impossible to wear the overlay out?  I mean if it comes from mamemarquees that is.  Scott's stuff is bulletproof.  Superman gets his suits made there.
somunny
« Reply #6 on: March 10, 2006, 05:34:30 pm »
Thanks for the opinions, guys.  I was originally going to use the Lexan.  When I received the overlay, I was so impressed by the quality and texture I started thinking that it would be nice to have it exposed.  Once again, I appreciate the comments.  The jury is out for now.
Steve
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #7 on: March 10, 2006, 05:40:12 pm »
Disclaimer: mccoy178 in no way condones the use of an overlay purchased from mamemarquees as a bullet proof vest.  mccoy178 does think that it would be good to hide under during inclement weather such as hurricanes or tornados.
ahofle
    • Arcade Ambience Project
« Reply #8 on: March 31, 2006, 05:47:57 pm »
Can someone comment on how thick/rigid the material mamemarquees uses is?  I am a little unhappy with the recessing job I did for my trackball mounting plate, and the vinyl CP overlay I have now really shows the imperfections.  It has also slightly wrinkled in spots.  If it were a little bit more rigid I think it would be perfect.
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
« Reply #9 on: March 31, 2006, 06:17:41 pm »
If it's not even, the overlay will show it.  Mine isn't even, I have a mamemarquees overlay, it does a good job of hiding the imperfections, and the only one that really says anything about it is me.  Others could care less, they just want to play.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #10 on: March 31, 2006, 07:07:47 pm »
It will show almost any indentations.
ahofle
« Reply #11 on: March 31, 2006, 09:37:30 pm »
Damn, was hoping it was thicker than the vinyl or shelf lining stuff.  Are there any other options out there such as attaching the artwork to a very thin but slightly rigid sheet of plastic or something?
