Author Topic: Pac Monitor Help  (Read 2200 times)
ArcadeNoob
  • Last login:March 16, 2007, 06:33:14 pm
Pac Monitor Help
« on: March 06, 2006, 07:40:30 pm »
So Ive got a PacMan in the original cabinet.  Everything is original.  I just had it serviced professionally(for another reason) and now, the monitor blinks a little bit; it squeezes inwards once or twice for a second or two every few games.  I was just playing it, and at the second cut scene where the ghost gets "stuck", the monitor went blank except for a thin white line through the center.  It came back about 30 seconds later, but Im wondering.......is it the beginning of the end? Any ideas for solutions? Thanks!
SirPeale
  • Green Mountain Man
Re: Pac Monitor Help
« Reply #1 on: March 06, 2006, 07:45:37 pm »
Sounds like it needs work.
If it's got the original Pac-Man monitor in it, it likely either has a (IIRC) WG4600 or an Electrohome G07 in it.
We'll need to know which it is to proceed from there.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: March 07, 2006, 12:33:09 am »
Common problem. You probably have a Wells-Gardner 19k4600 series monitor and it has bad solder joints causing the intermittent collapse. Your monitor definitely needs to be serviced----NOW.
ArcadeNoob
« Reply #3 on: March 07, 2006, 07:03:01 pm »
Anyway I can do it myself?  I dont have much more money to spend on it.  I will find out what monitor it is tomorrow; thanks!
Also, should I not play it in the meantime?
EDIT:  Its a WG 19K4606
« Last Edit: March 07, 2006, 07:37:24 pm by ArcadeNoob »
SirPeale
« Reply #4 on: March 07, 2006, 08:37:39 pm »
Well...you'll need a soldering iron, if you don't have one already.  Good starter one is a Weller WLC100.
If you haven't soldered before, get a scrap circuit board somewhere and PRACTICE!!!!  There are a lot of tricks to soldering, so before you mess up your monitor, practice on something you don't care about.  Number one hint I can give you off the top of my head: solder flows *UP*.  You'll see what I mean.
If it becomes that big of a deal, post your location, perhaps there's a tech nearby that will do it for a little $$$.  Heck, I'd do it if you're close enough.
ArcadeNoob
« Reply #5 on: March 07, 2006, 11:42:04 pm »
Tampa area.  Also, let me say this.........I have a friend who knows how to solder, but has never worked on a machine.  Ever.  Do you think there are detailed instructions that I could pass on to him and have him successfully complete?  Is it a difficult job?  What actually needs to be done? Thanks!
ArcadeNoob
« Reply #6 on: March 08, 2006, 10:27:47 pm »
Anyone?
Ken Layton
  • Guru
  • Technician
« Reply #7 on: March 09, 2006, 10:27:50 am »
This gets asked so often that I'm tired of answering.
 Please see the FAQ here and Google capkit instuctions/how to.
ArcadeNoob
« Reply #8 on: March 09, 2006, 04:08:15 pm »
So youre telling me it just needs a capkit, and thats it?
Ken Layton
  • Guru
  • Technician
« Reply #9 on: March 09, 2006, 05:35:31 pm »
Capkit and resolder any bad solder joints found (particularly at the daughter card connectors).
