Author Topic: U64 killer instinct emulator Sound De-sync & pop click sounds afer 10 mins?  (Read 1854 times)
hayabusa_fmw
  • [Provisionally returned]
  • Last login:December 30, 2014, 03:24:56 pm
HEllo everyone
I am experiencing an other weird issue with the latest U64 emulator. 3.05
I have KI 1 & KI II running
but after 10 mins on both but nearly 20 mins on KI 1 ..sounds become to be de syncronised & just pop click & become distortioned.......
The rest looks to run find maybe a slight slower but nothing major.................
all of the other game i played on my pc never had that type of problem
I have a 1.2ghz + 256 DDR ram
let me know
thanks!
motorfish
  • Last login:September 30, 2009, 03:35:08 am
get a 3.2 ghz PC and run KI1 and 2 in MAME perfectly. Don't bother with the U64emu, as it is no longer supported or updated.
Have you paid your dues Jack?......Yessir, the check is in the mail!
hayabusa_fmw
a little too pricey for what i do with this machine i think i will just drop the idea of playing those if its impossible.
motorfish
MAME is the only emulator that will play these properlyy, minus playing the original boards. Sorry.
hayabusa_fmw
too bad since i already got my pc Up & all... set up
I am desapointed since killer 1 & 2 are mainly the reason i became an arcade fanatic.
Cuba
  • Last login:September 20, 2019, 02:29:23 pm
my system is an AMD XP2500 with 2x512 pc2700 DDR. But in this case, only the CPU matters. With mame set to high priority it plays KI 1 perfectly, no dropped frames.  KI 2 run while dropping about 3 to 8 frames.  So my setup is right at the CPU power borderline.  Just thought you might like to know what it takes to run them in case you upgrade.......
