Author Topic: MameWah snaps  (Read 1901 times)
rhd
  • Last login:December 22, 2002, 09:42:53 am
  • Nothing is idiot proof
    • rhd
MameWah snaps
« on: February 19, 2003, 10:56:15 am »
What's the trick to getting snapshots to appear in MameWah? I found a configuration file that looks promising, but I don't know what format it expects.
Thanks,
Rob
Bill_S
  • Last login:June 22, 2018, 08:23:57 am
  • aka buzzdalf
Re:MameWah snaps
« Reply #1 on: February 19, 2003, 12:07:18 pm »
I just use the snaps downloaded from the web (png format I believe).
WOrks fine in MAMEWah, there's no real trick I know of.  All you have to do is tell it what directory the files are in (it's an item in mamewah.cfg I think)
  • Last login:Today at 12:17:00 am
Re:MameWah snaps
« Reply #2 on: February 19, 2003, 12:32:44 pm »
As in most fe's I believe you need to extract them, however.....
Re:MameWah snaps
« Reply #3 on: February 19, 2003, 02:44:03 pm »
You need to make sure you have a mame.ini (for windows mame.exe) or mame.cfg if you use dos mame.  MAMEWAH reads the location of your snaps from this file - make sure you have your snaps in the right directory.
And yes, Howards right, they should be unzipped png's.
That's assuming your using MAME - for other emus you can state the snap location in the 'Emulator Options' menu (& jpg's, pcx's, bmp's, gifs or png's can be used).
Let me know if you still can't get it to work...
rhd
    • rhd
Re:MameWah snaps
« Reply #4 on: February 19, 2003, 06:50:37 pm »
You were right. It worked like a charm. Thanks for the help guys.
Rob
