Author Topic: formica or vinyl?  (Read 2935 times)
aaron
formica or vinyl?
« on: April 13, 2002, 07:08:44 pm »
im down to the finishing touches on my cabinet, and would like to hear about others experiances with either using formica or if anyone has bought the black pica vinyl from happs? im leaning towards the happs vinyl right now unless someones had a bad experiance with it?
tellarite
  • Last login:Never
  • Codito Ergo Sum
    • Tellarite's MAME Cabinet
Re: formica or vinyl?
« Reply #1 on: April 13, 2002, 10:55:08 pm »
I used formica (formica brand in fact) on my control panel.. and I really like the way it turned out..
check it out at: http://www.tellarite.net/new-cabinet.php
I have no experience with the vinyl.
pyrobrit
  • Last login:December 15, 2002, 10:03:23 am
  • Working on armchair CPs
« Reply #2 on: April 14, 2002, 05:15:51 am »
I've been looking for a supplier of Formica or some other hard wearing surface in the UK with no luck so far.
However on Saturday I came accross Fireplace surround in the Wicks DIY store chain.  It is 3mm thick and has two higly polished patterned surfaces so you can reverse it to the one you prefer.
It is available in two sizes.  One size which is in the shape of a fireplace and the other which is 300mm X 600mm X 3mm and costs
Mannix2
  • Last login:February 18, 2009, 07:21:15 pm
    • Merl's Mame Machine
« Reply #3 on: April 14, 2002, 06:21:38 am »
I went with the formica product.  Found it at Lowe's-4 x 8 sheet only 20.00.  I have two young daughters who really beat on the control panel, and after 2 years, not a scratch.  Vinyl doesn't sound as durable.  You will need a router though if you go with the formica.  Check out my site for photos.
http://members.tripod.com/mannix20/index.htm
Good Luck!
Mike C
Mannix2
