Author Topic: DIY coin pusher?  (Read 4563 times)
spystyle
DIY coin pusher?
« on: February 28, 2006, 08:23:51 pm »
Hello from icy cold Maine,
Recently a pal of mine asked if we know how to build "coin pushers" - While it sounds unlikely I know some of us are building pinball machines and skeeball.
Anyone have any plans or even a repair manual for one of these?
Thanks,
Craig
Flinkly
Re: DIY coin pusher?
« Reply #1 on: March 01, 2006, 12:42:16 pm »
that would be simple.  they are just a ramp where you control when to let them loose.  from there, you'd make each target a switch when you knocked them down, and a solenoid to set them back up, then just make a box to go around it and a comp to remember how much each target is worth and to display your score when your done.  as for making one, i'd buy one if it were me, too much cost for so little, and you could probably pick one up for a 100 if you found one.  try talking to your local arcade owner for some coin-op names to contact.
good luck.
