Author Topic: snapping, arcing with megatouch  (Read 1362 times)
markymarky99
  • Last login:August 20, 2017, 01:53:05 pm
« on: February 28, 2006, 02:32:30 am »
i picked up what i thought was a nice megatouch 8000.  After playing for a bit, the screen started to snap and shake.  I looked in through the back and I can see a spark from the very bottom of the SUCTION CUP of the anode to the metal frame.  Any ideas what might be causing this ?  as always, thanks guys!
SirPeale
  • Green Mountain Man
Re: snapping, arcing with megatouch
« Reply #1 on: February 28, 2006, 07:00:57 am »
Condensation under the anode cap.
menace
« Reply #2 on: February 28, 2006, 07:34:18 am »
also make sure th anode cap is securely fastened to the tube--if its loose or not fully clamped in you can get leakage.  You might also have some dirt or build up that is conducting juice out from the anode cap--keep in mind you will have to discharge it to clean it thoroughly in that area.  Don't let it arc for too long or your tube will get etched from the arcs and potentially ruined.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: February 28, 2006, 11:11:49 am »
And make sure the touchscreen ground wires are connected. Also make sure the machine has it's power cord ground prong intact.
