Author Topic: solid black line in the middle of monitor  (Read 1405 times)
POS
  • Last login:March 22, 2006, 01:31:02 pm
« on: February 27, 2006, 11:06:03 pm »
I've loaded Fraggals boot CD.  I start up the pc I have to use a pc monitor to start out with but once it goes into Arcadeos I plug in my Arcade moniotr and looks good.  no Flicker very clean.  but when I exe a ROM I get the black line down the middle.  Is thsi a resolution issue? and is their any way to keep the arcade monitor on the whole time without having to keep swaping monitors
SirPeale
  • Green Mountain Man
Re: solid black line in the middle of monitor
« Reply #1 on: February 28, 2006, 07:28:37 am »
Why do you have to swap monitors at all?
Can you show us a picture of the 'black line' please?
Orclord
  • Last login:October 16, 2009, 03:09:38 pm
« Reply #2 on: February 28, 2006, 02:45:17 pm »
Also iirc there was a setting in arcadeos.cfg
#Beep through SB if found
beepfm=0
This would beep when arcadeos had loaded so you could turn your monitor on...
