Author Topic: problem with midway games on mame32  (Read 1645 times)
mrcram
  • Last login:October 07, 2016, 05:47:03 am
  • OREGON STATE
« on: February 26, 2006, 04:18:43 pm »
I tried to search for topic, but couldnt find. I am running mame32 on windows xp with a jpac and an arcadevga on a 25'' wellsgardener arcade monitor. every game plays good except the midway ones( mortal kombat series, wrestlemania) the screen keeps on scrolling. How can I fix this?
markrvp
  • NFL Expert
Re: problem with midway games on mame32
« Reply #1 on: February 26, 2006, 04:49:36 pm »
I'm pretty sure it is a refresh frequency problem.  According to the game info (image #1 below), the screen refresh frequency for MK was 53.204948 Hz.
Look at Image #2 below.  In the ADVANCED tab of Mame32 I would try changing the refresh frequency to different settings (use 53 Hz if you have it).  Choose one setting and launch the game.  If it works, you're done.  If it doesn't, hit ESC and then try another frequency.  Be sure and hit APPLY at the bottom of the settings window before hitting okay.
If none of the frequency settings make it work, then you probably want to force the resolution and select HARDWARE STRETCH.  I would use 640x288 to start with and then go through the routine of choosing the refresh rates until one works.  Once you find a setting that works, then you can try different resolution settings to see if you get one that most closely fills the screen.
Good luck.
PS - click on the images to make them full size and readable.
subcriminal
  • Last login:November 20, 2019, 12:58:00 pm
« Reply #2 on: February 27, 2006, 01:45:15 pm »
Adjust v hold on the monitor. It might be set just on the limit for normal refresh rates giving a steady picture but not enough for 53hz. I always adjust my v hold for MK and it's ok for everything then. Worth a try.
