Author Topic: i-pac or keywiz??  (Read 2800 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
i-pac or keywiz??
« on: February 23, 2006, 02:28:49 pm »
So what do you guys think is better, the i-pac or keywiz and why?  I am leaning toward the i-pac4 since I will need almost all the inputs.  I will also be getting an optipac or the one grooveygamegear makes.
« Last Edit: February 23, 2006, 02:42:18 pm by squirrellydw »
I b**ch. People listen!!
deadkenndys1105
  • Last login:November 27, 2012, 03:55:05 pm
Re: i-pac or keywiz??
« Reply #1 on: February 23, 2006, 02:35:30 pm »
Go with the i-pac. I just got mine in the mail today. I dont know anything about the other one tho. :P
17 years old and totaly addicted.
koolmoecraig
    • My Intervention
« Reply #2 on: February 23, 2006, 02:38:58 pm »
Great advice. Go with the I-pac because he just got his in the mail today. Brilliant.
miles2912
« Reply #3 on: February 23, 2006, 02:42:25 pm »
Go with a mini-pac.  Mine came 6 months ago!
Serious tho.. there are a lot of questions you have to ask yourself.  How many buttons?  2 player of 4?  Trackball?  Spinner?   Design your CP and then buy or hack an encoder to meet your needs.
Don
markrvp
  • NFL Expert
« Reply #4 on: February 23, 2006, 02:52:22 pm »
That's kind of like, "Ford or Chevy"
If you need all the inputs of the Ipac4 then that is certainly the most elegant solution.  I've got both products and like them both very much.
squirrellydw
« Reply #5 on: February 23, 2006, 02:57:13 pm »
OK, so there are no disadvantages over one or the other?  What about for trackballs and spinners?  I will have two trackballs and probably one but maybe two spinners?  Optipac will work for that correct?
markrvp
  • NFL Expert
« Reply #6 on: February 23, 2006, 02:59:43 pm »
Yes.  If that is the route you want to go, then buying both encoders from the same vendor makes sense.
The Opti-pac is probably easier to set up for simultaneous 2-trackball games.  You are talking about 6 axes, and the Optiwiz is 3 axes, so you would need two Opti-Wiz encoders to handle all of those.
« Last Edit: February 23, 2006, 06:32:44 pm by markrvp »
AC.
  • Last login:January 21, 2015, 03:55:07 pm
    • MAME console
« Reply #7 on: February 23, 2006, 03:05:15 pm »
Debbie! The Car!  Debbie! The Car!
squirrellydw
« Reply #8 on: February 23, 2006, 03:14:07 pm »
I will be going with the i-pac and optipac.
thanks, you guys have been a big help again.
« Reply #9 on: February 23, 2006, 03:31:53 pm »
I went with a grilled cheese.  I'm having some issues with it but it sure smells yummy.
Tiger-Heli
    • Tiger-Heli
« Reply #10 on: February 23, 2006, 04:02:27 pm »
Yep - this was the most non-sensible thread I have read in a long time.
See http://www.mameworld.net/tigerheli/encoder/index.htm - there are tons of differences between them.  Whether any of those matter for your application???
I doubt there's a valid reason you need all the inputs of an I-PAC/4, but I could be wrong.
If you do, the combination of a KeyWiz and a GP-Wiz, could be less expensive, if that works for you.
Ford, no wait, Chevy . . . Honda???
kingflynn
  • Last login:May 01, 2023, 07:39:02 am
« Reply #11 on: February 23, 2006, 06:08:29 pm »
I love the KeyWiz.  Easy to wire, well made, and it ships fast.
SurferMatti
  • Last login:October 12, 2006, 10:28:31 pm
« Reply #12 on: February 23, 2006, 07:17:30 pm »
Hi,
  Question about the Ipac and Mini pac...  I believe you can hook up 2 perfect 360's to the Ipac2 as long as you run in a 5v, correct?  Does the Mini pac also have a way to hook a couple of happ perfect 360's up to it?
markrvp
  • NFL Expert
« Reply #13 on: February 23, 2006, 07:29:29 pm »
Yes, there is a 10 pin header with three 5v taps.
SurferMatti
« Reply #14 on: February 23, 2006, 07:50:47 pm »
Ok cool thanks...  So in order to use the Perfect's with the Mini Pac must I have the Mini Pac w/ the optional Optical inputs (69$ one),  or is that only used for the trackball/spinner, and a Mini Pac Standard will work?
miles2912
« Reply #15 on: February 23, 2006, 08:38:41 pm »
That 10 pin header plugs into the mini pac if you want to use a trackball and/or spinner.  If not then you can use it for whatever.
Don
markrvp
  • NFL Expert
« Reply #16 on: February 23, 2006, 09:11:08 pm »
It is my understanding that there are no differences in the Minipac boards.  The difference is the harness which either does or does not have the connections for the optical devices.  If anybody can confirm this I would appreciate it.
Tiger-Heli
    • Tiger-Heli
« Reply #17 on: February 25, 2006, 08:48:06 am »
That's what I've heard also.  I was told a future version might not have all the code embedded, but currently all the Mini-Pac boards are identical and only the harnesses are different.
