September 15, 2025, 11:48:19 am
It would have to be a fairly small and light wheel due to the thin 1/4" shaft of the spinner.1/4" is more than sturdy for a spinner with its short stubby knob, but a wheel could be used to bend the shaft.
Just as a thought, how about offering a steering wheel that could be attached to your new spinner? It could either attach directly to the shaft or more conveniently, somehow, to the spinner knob.Thanks for listening.
Maybe it wouldn't have to connect directly to the spinner.I'm thinking some sort of friction wheel or gear-like set up if you can picture what I'm trying to articulate.Dunno if that's more trouble than it's worth though....
However you would have to reverse the outputs from the spinner if only using two meshing gears.
Quote from: Dizzle on February 23, 2006, 09:25:30 pmMaybe it wouldn't have to connect directly to the spinner.I'm thinking some sort of friction wheel or gear-like set up if you can picture what I'm trying to articulate.Something like this?
