Author Topic: monitor not working?  (Read 1203 times)
thorkon
  • Newbie
  • Last login:February 24, 2006, 11:08:55 pm
« on: February 22, 2006, 05:54:05 pm »
so here goes:
I recently snatched a street fighter II arcade from someones trash a week ago. i plugged it in and held the power button in the back in while it started (if i let it go it turns off) after a little bit i could here music and whatnot and when i got to the front to look at the screen theres only one thin line of light/colors going down the middle then black on either side. i see the colors changing as if the games running and i hit the buttons and joystick and i hear sound recognizing there being pressed. is the monitor no good or maybe a loose cable or somehting else i need to do? im curious if theres a chance that i can get it to work. thank you for the responses
Ken Layton
  • Guru
  • Technician
Re: monitor not working?
« Reply #1 on: February 22, 2006, 06:26:00 pm »
Pulling outward on the back door "interlock" switch bypasses it for servicing the machine.
First thing to do is look for obvious problems on the monitor: loose cables & connectors. Next thing to do is identify the specific make & model of the monitor. What size is the picture tube, 19" or 25" (diagonal measurement just like tv sets)?
