Author Topic: 1992 RCA 27" monitor  (Read 4601 times)
toddman1
  • Last login:March 20, 2006, 04:27:05 pm
« on: February 21, 2006, 11:07:44 am »
I want to convert my Dungeons & Dragons to a mame. It has a 1992 27" RCA Arcade Monitor tube type A63ADT10X05, model # P3-E05CM31. The monitor would work for about 15 minutes and then would just shut down.  Any suggestions on what to check ? Does anyone have any tech specs on this model ?
Thanks.
Ken Layton
  • Guru
  • Technician
Re: 1992 RCA 27" monitor
« Reply #1 on: February 21, 2006, 11:41:31 am »
RCA does NOT make commercial arcade game monitors.
toddman1
« Reply #2 on: February 21, 2006, 12:29:35 pm »
That's the info I got from the monitor. Any suggestions on what to check for the black out after 15 minutes ?
Atomiswave
  • Last login:June 26, 2006, 01:19:02 pm
« Reply #3 on: February 21, 2006, 12:39:12 pm »
Please tell us the brand of your chassis. I highly doubt the picture tube is behind your issue. I believe you have a Wells Gardner chassis, but we need to know the model of it. RCA/Thomson used to supply some monitor manufacturers.
toddman1
« Reply #4 on: February 21, 2006, 01:32:40 pm »
It think it is a wells gardner 7000.
grantspain
« Reply #5 on: February 21, 2006, 04:06:49 pm »
if your monitor is cutting out after a short time you are looking at a heat related problem,if its an old chassis its likely either to be a dry joint on  one of the componants or a electrolitic cap.start looking for dry joints especially round the lopti,if none found then get a cap kit.
toddman1
« Reply #6 on: February 21, 2006, 04:38:12 pm »
Thanks.
toddman1
« Reply #7 on: February 23, 2006, 11:28:26 am »
After some more dgging around. My monitor is actually an old Hantarex Polo chasis. Does anyone know what I can get parts for the monitor ?
grantspain
« Reply #8 on: February 23, 2006, 12:03:16 pm »
if you have a hantarex polo 1 chassis all the parts you need can be purchased at any componant dealer,if your in the u.k someone like maplins.when your monitor cuts out do hear a ticking from the chassis or can you see an orange glow from the tube neck?
Ken Layton
  • Guru
  • Technician
« Reply #9 on: February 23, 2006, 12:15:47 pm »
The Hantarex distributor in the USA is the R.H. Belam Company (www.belamny.com) .
toddman1
« Reply #10 on: February 24, 2006, 11:34:06 am »
Thanks.
toddman1
« Reply #11 on: February 24, 2006, 11:35:06 am »
When the monitor cuts out, I don't see an Orange glow or ticking.
grantspain
« Reply #12 on: February 24, 2006, 11:53:25 am »
now your fault lends itself to being a dry joint,probably on your lopti(flyback transformer)
