Author Topic: Atomic and avi files possable?  (Read 1204 times)
daywane
  • GRRRR!
« on: February 20, 2006, 08:12:49 pm »
if not avi files is another format able to play?
Atomic is becoming my dream entertainment FE
only a few things missing that I would love to see.
GBA
2600
PS1 ( not really a must... I have a modded PS1 and PS2 )
I think you allready have a mp3 player... need to check more into it
But My favorite movie's on Hard drive with my console PC would be really great with the same FE.
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Atomic and avi files possable?
« Reply #1 on: February 21, 2006, 03:58:59 am »
Hi,
For modules you ask they are coming soon.
Concerning Video. Atomic include a Video JukeBox. It can play all format that can play Mediaplayer . (to try if your media player can play the video , just run mplayer2.exe that is in your windows or windows\system32 folder).  If you have the right codecs , your video will be played fullscreen without problems.  Codecs pack can be found on web.
Atomic can play XVID video that way , if used has Video Jukebox. (not snap).
Now, if you want use VIDEO SNAP. I support all AVI format as soon as the codec is here. But i have problem with the XVID avi format.  After investigation i found the issue.
The XVID codec is not complete! One function is not implemented , and that is a function i use. for video snap.  >:(
But i have found a work around.  By removing the XVID codec and using another codec.
To remove the XVID codec , go to control panel -> sound and Multimedia -> Hardware Tab ->select Video codec in the list -> click properties   -> Properties tab -> Select "XVID MP4 Video codec" -> Click remove.
Then you can try the video snap in Atomic. If the video displays it is ok, it not, it is because you don't have a compatible codec already installed. So try to find and install this codec :
DSH   4CC   DIVX
DSH   Friendly Name   DivX Decoder Filter
DSH   Driver or Wrapper   H:\WINDOWS\System32\divxdec.ax
DSH   DirectShow CLSID   4cc: divx     {78766964-0000-0010-8000-00AA00389B71}
FIL   File Description   DivX
