Author Topic: Cabs w/ 19" monitors  (Read 2473 times)
toasty
  • Last login:October 10, 2019, 11:48:47 am
  • Purveyor of Fine Latex Products
« on: February 20, 2006, 04:52:49 pm »
Hey folks.  Anyone have any pictures of cabinets that have used 19" computer monitors?
Obviously, bigger is better and I've often seen people harp on those who build a cab and then plug a 19" monitor in there, but I stumbled upon a cheap 19" computer monitor, so if it doesn't look terrible, it could greatly streamline my project.  I'm mostly curious what a 19" monitor looks like in a Lusid-style cab, since I plan to have a fairly large control panel that might look odd if it was on a more narrow cabinet built for a smaller monitor.
TIA
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
Re: Cabs w/ 19" monitors
« Reply #1 on: February 20, 2006, 04:56:53 pm »
In a Lusid style cab it will look really small. It would look marginal in a classics cabinet.
I have build cabinets around smaller monitors, but you have to proportion them correctly or they look weird.
Chris
    • Chris's MAME Cabinet
« Reply #2 on: February 20, 2006, 05:24:10 pm »
Why marginal?  Didn't most classics use 19" monitors?
This is my cabinet when it had a MAG 19" PC monitor in it.  The cabinet was originally a Konami Super Contra (stripped and painted black before I got it), and is 23" wide:
--Chris
--Chris
alomar721
  • Last login:November 01, 2007, 11:09:59 pm
« Reply #3 on: February 20, 2006, 05:53:28 pm »
i see your cabinet i like it do you have a pic of the control up close i understand the buttons near joystick what are the ones at the top thanks
scott
yeah im going need you to work on saturday mmmm ok.
Chris
« Reply #4 on: February 20, 2006, 06:01:13 pm »
That particular control panel has been replaced, but along the top is Shift, Player 1 Start, left trackball, right trackball, player 2 start, Pause, and Exit.
--Chris
--Chris
koolmoecraig
    • My Intervention
« Reply #5 on: February 20, 2006, 06:57:58 pm »
What do you mean "marginal"?  99% of all of the classics used 19" monitors. If you trying stuffing something bigger that that into a classic cabinet it looks awkward.
19" is the PERFECT size for a classic cab.
quarterback
« Reply #6 on: February 20, 2006, 07:01:51 pm »
One thing to keep in mind is that a 19" CRT computer monitor and a 19" arcade monitor are not the same size.
A 21" computer monitor will have the same viewable screen as a 19" arcade monitor.  A 19" computer monitor will be smaller than a 19" arcade monitor.
-- Chad Tower
markrvp
  • NFL Expert
« Reply #7 on: February 20, 2006, 07:07:55 pm »
Remember that most classics using 19" monitors used bezels and then had large beautiful artwork surrounding the monitor.  The art was screen-printed behind the glass. If you use a 19" monitor with a plain black bezel without attractive art it looks too small.  I know I'm not the only one who thinks that because it's been discussed here quite often.  Check the Crapmame thread for some examples.
NoOne=NBA=
« Reply #8 on: February 20, 2006, 07:33:59 pm »
I posted pics of my monitor bezel here.
The farther back you put a smaller monitor, the larger it will look on the front glass.
I had a 21" set right up flush to the glass on that cab, and swapped it out for a 19" vertical monitor.
The 19" actually appears larger leaned back off the glass than the 21" did flush to it.
The front glass on that cab is 24" square.
HERE is a pic of the same cab with the 21" monitor on it.
Notice how much more of the front glass is covered with art, vs. the 19" laid back with a bezel.
nostrebor
  • SHOCKING!!
« Reply #9 on: February 21, 2006, 09:55:53 am »
This is what I mean by marginal. it takes a 21" PC monitor to get back to original arcade dimensions. Also my statement is what we call an "opinion". In laymans terms, that means it is not gospel. :P
Stingray
« Reply #10 on: February 21, 2006, 01:03:43 pm »
19" arcade monitors are bigger than 19" computer monitors. You won't believe me until you go and measure them for yourself. I'll wait.
-S
nostrebor
  • SHOCKING!!
« Reply #11 on: February 21, 2006, 01:45:33 pm »
19 is the new 21 :)
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
« Reply #12 on: February 21, 2006, 02:32:59 pm »
"viewable image" vs. tube dimensions.
Somewhere in the early nineties monitor manufacturers stopped using how big the picture is and moved to how big the tube is.  A 1989 Apple 12" monitor is the same size as a 1993 Apple 13".
So, yeah.  There you go.  Buy a bigger computer monitor to fit the "same" size arcade monitor's space.
Chris
« Reply #13 on: February 21, 2006, 02:55:29 pm »
I'm glad they don't seem to be able to get away with this for LCD's!
--Chris
